PeterPan9720 Posted May 28, 2010 Share Posted May 28, 2010 So we helps each others ! So may you help me with another little issue that I have ? see my post: http://www.cadtutor.net/forum/showthread.php?t=48394&goto=newpost Thank you, a big bear for you ! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 28, 2010 Author Share Posted May 28, 2010 Just to clarify the program does sort the tags/blocks properly - I doubted the program for a minute. I already looked at your other problem Quote Link to comment Share on other sites More sharing options...
PeterPan9720 Posted June 4, 2010 Share Posted June 4, 2010 Just to clarify the program does sort the tags/blocks properly - I doubted the program for a minute. I already looked at your other problem Thank you for your answer, is there a way send back in to the selected blocks the result file manipulated for example : a block attributes placed in different layers contain a sequential number that has been copied several times in the drawing but it's wrong. So if I extract data, then I manipulate, and send back to the drawing may I save time. Thks Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 4, 2010 Author Share Posted June 4, 2010 I haven't added this ability to the program as yet - as there are many formats that the extracted data may take, and, without extracting the block entity handles, it is impossible to know which block the data was extracted from. Quote Link to comment Share on other sites More sharing options...
PeterPan9720 Posted June 4, 2010 Share Posted June 4, 2010 Excellent Sorry to stress the forum with my issue. Pls could you help me to extract the section of the above lisp that extract the coords of the blocks in the drawing. I'll add to the ATTOUT lsp in the express tools and I solve all my problems. Thank you Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 4, 2010 Author Share Posted June 4, 2010 Look at either the DXF group 10 code of a block entity, or the InsertionPoint property of a VLA Block Reference Object. Quote Link to comment Share on other sites More sharing options...
PeterPan9720 Posted June 4, 2010 Share Posted June 4, 2010 Look at either the DXF group 10 code of a block entity, or the InsertionPoint property of a VLA Block Reference Object. Thank you very much for your support I'll do this, but coyld you help me to find the instruction in your lsp ?- Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 4, 2010 Author Share Posted June 4, 2010 It will not help you - it is written specifically for this program. Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted June 4, 2010 Share Posted June 4, 2010 hello i start to play with att editor. this is fantastic tool but i noticed few things: Will it? Oh right, if you say so..Hi Guys, Yes, I did produce an attribute editor by the same name, but I didn't pursue it too much, as there is a known bug with ObjectDBX that loses the DWG thumbnail, and can alter the position of attributes when you save the drawing. 1. is there any solution for this? after editing attribute in closed dwg's attribute change position a little bit (i need to make attsync). i will start testing att editor next week at work and see how much this affect the attribute. 2. as someone noticed all dwg are saved to acad version we are working on (2010 in my case). i think the best format for save dwg is 2004 (so far the smallest file size). i'm a draftsmen but my client usually use old version of cad. they just print them and that's all. so save files to newest version are not prohibited. One of the advantages of my program over Data Extraction is that it can process multiple drawings at the same time. 3. i think that data extractions also works on multiple dwg's:) sorry for my language. my english sucks. thanks kruuger PS i'm starting to be addicted from your programs. awesome work!!! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 5, 2010 Author Share Posted June 5, 2010 Hi Kruuger, I'm glad that you are liking my programs - I'd write a lot more if I had the ideas Perhaps DataExtraction does process multiple drawings, but I enjoyed writing this program - so I'm not disappointed. As for the bugs you mentioned... In my mind, interfacing with ObjectDBX is, although great for most tasks, it isn't fully developed, so there are a few bugs that are to be dealt with. I included a function to attempt to correct the attribute position when updating, but this is not 100% foolproof and may fail. The attribute position will be updated when the block is either moved, or of course through attsync. As for the thumbnail, yet another bug that I have no control of when using LISP - this can be worked around using a more powerful language such as .Net or Arx, but suffice to say the drawing thumbnail is returned when the drawing is next manually saved. With all this said - none of these bugs will affect the Global Attribute Extractor, as this doesn't attempt to modify the drawing contents, nor save the drawing. Lee Quote Link to comment Share on other sites More sharing options...
Guest kruuger Posted June 5, 2010 Share Posted June 5, 2010 Hi Kruuger,With all this said - none of these bugs will affect the Global Attribute Extractor, as this doesn't attempt to modify the drawing contents, nor save the drawing. Lee yes, extractor works perfect. in my case i love your editor. for example i need to update submittal date in 30 dwg's. now there will be no problem with your tools:) I'm glad that you are liking my programs - I'd write a lot more if I had the ideas hmm, rather simple and small tool but.. how many people wants to hatch enclosed area? i was thinkg about tool to hatch selected line, circle, pline etc. with offset input by user. please see attached picture for clarification. what do you think? thanks kruuger Quote Link to comment Share on other sites More sharing options...
muck Posted June 15, 2010 Share Posted June 15, 2010 Where does the program put the excel file and does excel need to be open when the program runs? Thank you Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 15, 2010 Author Share Posted June 15, 2010 Hi Muck, The Excel file isn't saved - this is left for the user, Excel doesn't need to be open when the program is run. Lee Quote Link to comment Share on other sites More sharing options...
PeterPan9720 Posted June 15, 2010 Share Posted June 15, 2010 Where does the program put the excel file and does excel need to be open whenthe program runs? Thank you Here is a part of code for managing an excel file, usually I open an empty Sheet of Excel, please chek the name of Excel Sheet ("Foglio1", or "Sheet1" or any name you want). ' Start Excel if not running On Error Resume Next Set MyExcel = GetObject(, "Excel.Application") If Err.Number <> 0 Then ExcelWasNotRunning = True Err.Clear ' Clear Err object in case error occurred. ' Check for Microsoft Excel. If Microsoft Excel is running, ' enter it into the Running Object table. If Err <> 0 Then Err.Clear Set MyExcel = CreateObject("Excel.Application") If Err <> 0 Then MsgBox "Could Not Load Excel!", vbExclamation End End If End If On Error GoTo 0 MyExcel.Visible = True 'Excel.Workbooks.Add MyExcel.Sheets("Foglio1").Select ''Worksheets("Sheet1").Activate Set MyExcelSheet = MyExcel.ActiveWorkbook.Sheets("Foglio1") MyExcelSheet.Range("1:1").Font.Bold = True ''Clear the cells 'MyExcelSheet.Range(Cells(1, 1), Cells(100, 100)).Clear ... ... MyExcelSheet.Cells(Row, Col ).Value = "HANDLE" Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted June 21, 2010 Author Share Posted June 21, 2010 Thanks to a recent bug report, I have updated the program to Version 2.9 Quote Link to comment Share on other sites More sharing options...
snrabnaz Posted July 13, 2010 Share Posted July 13, 2010 Thanks Dear Lee, Iam nazeer from India. Thanks you for this great free ware. May God Bless You and reward You I have used your "Global Attribute Change" works great I should Thank you. bye Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted July 13, 2010 Author Share Posted July 13, 2010 Glad that I could be of help Lee Quote Link to comment Share on other sites More sharing options...
rmartin7 Posted August 15, 2010 Share Posted August 15, 2010 Hi Lee, This is a great application thanks, I am hoping you can add some wildcard functionality to it somehow. I have a directory full of files all with the same attributed block with varying values, I only need to change one character of the value: ex. 1000A1000L needs to be updated to 1000B1000L, each drawing value is different from the next. I tried this for new value but it didn't work: ####B####@. It changed all drawings to the value: 1000A1000L. I look forward to using the current functionality of your great application. Thanks Have a spectacular day! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted August 16, 2010 Author Share Posted August 16, 2010 Hi Martin, I'm glad you enjoy the program - currently, as you know the attribute editor will update only those that have an 'exact match' to that which is specified - I may include an option to use wildcards (a la FIND) in the future, but I don't have too much time to work on this I'm afraid. Lee Quote Link to comment Share on other sites More sharing options...
rmartin7 Posted August 16, 2010 Share Posted August 16, 2010 Hi Martin, I'm glad you enjoy the program - currently, as you know the attribute editor will update only those that have an 'exact match' to that which is specified - I may include an option to use wildcards (a la FIND) in the future, but I don't have too much time to work on this I'm afraid. Lee Thanks for the response, I completely understand, I have become quite busy myself lately. Still, quite a useful tool, Thanks again for the great effort, I look forward to future updates. Have a Spectacular day! Quote Link to comment Share on other sites More sharing options...
