Guest kruuger
works perfect cad 2011 (latest update 1.1) with office 07, editor and extractor.
kruuger
  maclukas said:
There is a very nice 'Block Attribute Global Processor v2000-2011' which you can download from 'www.cadavista.com'
Mac Lukas
Worth to note that CADavista is a company that sells BAGP.vlx. It is not a free program.
I made a macro myself which extracts blocks attributes from DWG to excel.
I'm using for the creation of marshalling section in electrical panel drawing.
Well done to you :roll:
  Astro said:
Hi Lee,
Great tool thank you it helped me a lot. One question, would it be possible when exporting to have the object handle id also in the excel?
this would allow us to edit the attributes in excel and than use the "attin" command to import the informations back into the drawing :D
Perhaps, although I don't have the time to update the program currently I'm afraid.
  • 3 weeks later...
Hi,
When I try to run the .lisp routine, I get the following error:
  Quote
Command: (LOAD "C:/autolisp/macatt.lsp")
¤º°`°º¤ø,¸¸, MacAtt.lsp ~ Copyright © by Lee McDonnell ,¸¸,ø¤º°`°º¤
~¤~ Extractor: "MacAttExt" -==- Editor: "MacAttEdit" ~¤~
Command: macatt
[Editor/eXtractor] :
"1"
nil
"C:\\autolisp\\"
"0"
"grp_file"
"0"
"1"
nil
"C:\\autolisp\\"
"0"
nil
** Error: bad argument type: streamp nil **
I've tried to trouble shoot it, and it happens at line 346:
  Quote
(setq ofile (close ofile))
Any help would be much appreciated.
Thanks for the quick reply. I'm glad the error wasn't me :wink:
Please try Version 3.1 in the first post - I made quite a few changes to the subfunctions, so there may be a few typo's lurking...
Thanks, it worked for me.
One more question though, the block that I am trying to edit has some attributes with tags that end in an asterik, such as "base_drawing*". The routine seems to not like the asteriks, as it edits the tags that don't have one. I get the "Attribute tag not valid" message.
To clarify, I have a block called "TitleBLKATT", and it has several tags within it. Most are named with an asterik at the end, "discipline*", and others are without one, "Drawn_By". The routine works great on the ones without the asterik, but I get the error warning when I try and change any of the tags that end with "*".
I could change the block definition for the future, but I am trying to use the routine on a large set of existing drawings.
Thanks again.
  • 2 weeks later...
Hi!
I have that attribute editor. It's fantastic job LeeMac. I see one issue thoogh. I edit attributes (text) and when the alignment is centered it moves the text. I edited the "BYGGHANDLING" text from another value.
Alltghough when the justification is LEFT it's okay.
I have not the 3.1 but one of your previous versions. Please tell if the code is the same what lines are effected. The text alignment X,Y is pointing to just below the letter "B" where the text starts and so it moves the text.
Can I maybe change the text alignment to point at the justification position of the text, in that case CENTER?
Thanks for a program which really is makign everyone smile!
See the image:
This bug is known and described in the code header - it is nigh unavoidable when using ObjectDBX to process the drawings - the attributes are realligned when the drawing is updated manually...
Right,
Your BFind-program seems to work though. :) It seems to re-align.
I have not had any alignment problems either... :)
You only use Left? When I use Center it realigns to Left.
I did have that same problem, but for some reason I have not had that issue in some time. Within all my blocks, I use almost all the different types of alignments. Maybe I am doing something different within my blocks, but I have not had any alignment problems in some time.
** I am sure now that I say this I will find some issues, but my fingers are crossed... :)
  au-s said:
Damn you :)
Let see a block
Haha... I'll try and post a couple for you.
