Im wanting to be able to copy a file from a known location to the directory of the file i have open is in(will not always be the same), but im not sure where to start. Any advice?
Thanks.
In case i phrased the question very poorly. I want to copy 1.dwg from..Ex: C:\ACAD\1.dwg to the directory that the file i have open is in. (..\Refs).
I would be thankfull for any sugestions.
This may help, it will open Windows Explorer in the folder of the dwg you have open.
(startapp "explorer" (strcat "/e,"(getvar "dwgprefix")))
From Developer Help:
  Quote
vl-file-copy
Copies or appends the contents of one file to another file
(vl-file-copy source-file destination-file [append])
Copy or append the contents of one file to another file. The vl-file-copy function will not overwrite an existing file; it will only append to it.
Arguments
source-file
A string naming the file to be copied. If you do not specify a full path name, vl-file-copy looks in the AutoCAD default drawing directory.
destination-file
A string naming the destination file. If you do not specify a path name, vl-file-copy writes to the AutoCAD default drawing directory.
append
If specified and not nil, source-file is appended to destination-file (that is, copied to the end of the destination file).
Return Values
An integer, if the copy was successful; otherwise nil.
Some typical reasons for returning nil are
source-file is not readable
source-file is a directory
append? is absent or nil and destination-file exists
destination-file cannot be opened for output (that is, it is an illegal file name or a write-protected file)
source-file is the same as destination-file
Examples
Copy autoexec.bat to newauto.bat:
_$ (vl-file-copy "c:/autoexec.bat"
"c:/newauto.bat")
1417
Copy test.bat to newauto.bat:
_$ (vl-file-copy "c:/test.bat"
"c:/newauto.bat")
nil
The copy fails because newauto.bat already exists, and the append argument was not specified.
Repeat the previous command, but specify append:
"c:/newauto.bat" T)
185
The copy is successful because T was specified for the append argument.
Maby I missunderstood, what I thought would happen is that when I ran the lisp it would copy the file "W0114-150.dwg" into the directory of the drawing I had open at the time, but unfortunatly it did nothing. Can anyone please offer some advice on "vl-file-copy".
(vl-file-copy "C:/ACAD/Lisp/testLISPFORNEWWDSPULLDOWN/W0114-150.dwg" "" T)
you've only provided one file name.
It's looking for a source file AND a destination file
oops, you did provide two but the second one is ""
Thanks for the quick reply.
What I was shooting for was not to have to give it a destination I want the file name to be the same and the destination to be what ever directory the open drawing im working in is in. Is that possiable with this function or should I try to figure it out another way.?
For Ex: I will be working on
h:\00001\drawing1.dwg or
h:\00002\drawing1.dwg or
h:\00003\drawing1.dwg...ect...
and want to copy c:\drawingZ.dwg to
h:\00001\drawingZ.dwg or
h:\00002\drawingZ.dwg...ect....
The destination will change depending on what job/file I am working on. My plan is that after I figure out how to copy the file this way to also have this file xrefed in to the file I am working on to add certain details for specific conditions on jobs. The xref needs to be in the job folder and xrefed from their incase of special changes specific to that job, but I only want to add it to the job if I need it.
give this a try j-lyle,
(defun c:test (/ curr_dir  foldr&flname_2copy)
  (vl-load-com)
  (setq foldr&flname_2copy
   '("C:\\Documents and Settings\\wizman\\My Documents\\"	[color="blue"];<<< input here folder path of source[/color]
     "Drawing1.dwg"		                                [color="Blue"];<<< input here filename to be copied[/color]
  ) ;_ end_setq
  (if (findfile (apply 'strcat foldr&flname_2copy))
     (if (findfile (strcat (getvar "dwgprefix") (cadr foldr&flname_2copy)))
 (alert "\n File Exists in Destination Folder")
    (setq curr_dir (strcat (getvar "dwgprefix") (cadr foldr&flname_2copy)))
    (vl-file-copy (apply 'strcat foldr&flname_2copy) curr_dir)
    (prompt (strcat (strcase (cadr foldr&flname_2copy))
		    " copied to "
		    (strcase (getvar "dwgprefix"))
	    ) ;_ end_strcat
    ) ;_ end_prompt
 ) ;_ end_progn
     ) ;_ end_if
     (alert "\n Source File Does not Exist")
  ) ;_ end_if
) ;_ end_defun
Thanks for the reply, Hopefully I will have some time to give it a try latter on today. This will help alot.
Worked great! Thanks for the much needed help.
  • 4 months later...
(setq curdir (getvar "dwgprefix"))
(vl-file-copy "path and file.ext in here" curdir )
  • 10 years later...
     "Drawing1.dwg"
SOrry!! Help me!!!!
I want file name is input from editbox!!!
thanks!!!
  (vl-load-com)
  ) ;_ end_setq
		    " copied to "
	    ) ;_ end_strcat
    ) ;_ end_prompt
 ) ;_ end_progn
     ) ;_ end_if
  ) ;_ end_if
) ;_ end_defun
SOrry!! Help me!!!!
thanks!!!
Expand
Just look at the previous posts
(vl-file-copy "c:/autoexec.bat" "c:/newauto.bat")
or
(vl-file-copy File1 file2) where file1&2 are lisp variables
thanks!!!
Expand
Cheating acaddoc..
(setq fn (lisped "ABC.dwg"))[/Code]
  • 3 years later...
I know this is an old topic. How could I change this from a file to a folder with everything in it? I thought i would swap out the file name and extension to a (*
*), but not so much. Thank you for any pointers.
;;https://www.cadtutor.net/forum/topic/1138-copy-file-to-current-directory/
  (vl-load-com)
   '("C:\\Documents and Settings\\wizman\\My Documents\\"	;;[color="blue"];<<< input here folder path of source[/color]
;;     "Drawing1.dwg"		                                ;;[color="Blue"];<<< input here filename to be copied[/color]
     "*.*" ;;assuming for all folders and files
  ) ;_ end_setq
 (alert "\n Folder and Files Exist in Destination Folder")
		    " copied to "
	    ) ;_ end_strcat
    ) ;_ end_prompt
 ) ;_ end_progn
     ) ;_ end_if
     (alert "\n Source Folder and Files Do not Exist")
  ) ;_ end_if
) ;_ end_defun
Ok the answer is old fashioned DOS XCOPY, you can run windows CMD using (command "shell" "xcopydoscommand") so google xcopy as 1st step.
Edited by BIGAL
