Hi all,
I have made a little routine that will create a set of layers. What I would like to do now though, is to somehow add a loop with a counter so I can go all the way up to 99.
I could probably cut and paste my way out of this one instead, but something tells me that's not exactly the smartest way to go about doing this routine.
Also, adding a counter will allow me to control the amount of layers I want to create, or even add a prompt asking how many layers I want to create.
Can anyone show me how this can be done?
(defun C:TEST ()
(command "layer" "new" "LAYER-01-PRT,LAYER-02-PRT,LAYER-03-PRT" "color" "4" "LAYER*-PRT" "")
(command "layer" "new" "LAYER-01-CEN,LAYER-02-CEN,LAYER-03-CEN" "color" "1" "LAYER*-CEN" "ltype" "CENTER2" "LAYER*-CEN" "")
(command "layer" "new" "LAYER-01-DIM,LAYER-02-DIM,LAYER-03-DIM" "color" "1" "LAYER*-DIM" "")
(command "layer" "new" "LAYER-01-HID,LAYER-02-HID,LAYER-03-HID" "color" "6" "LAYER*-HID" "ltype" "HIDDEN2" "LAYER*-HID" "")
Pretty easy to do in lisp just need to create a string answer
here is a start not complete code
(setq x (getint "\n Enter number of layers"))
(command "layer" "New") ;start laynew
(repeat x
(setq num (rtos x 2 0))
(setq newlay (strcat "layer-" num "-prt"))
(command newlay)
) ; end repeat x times
(command "") ; end lay new
you could do smart things like a defun for the repeated code but copy and paste is probably easier first go
If I were you, I would definitely use an ENTMAKE method to create the layers - it'll be about 100x faster...
(defun c:test (/ x len i j)
 (initget 7)
 (setq x (getint "\nHow Many: ") len (strlen (itoa x)) i 1)
 (repeat x
   (setq j (itoa i))
   (while (< (strlen j) len)
     (setq j (strcat "0" j)))
   (Make_Lay
     (strcat "LAYER-" j "-PRT") 4 "CONTINUOUS")
   (Make_Lay
     (strcat "LAYER-" j "-CEN") 1 "CENTER2")
   (Make_Lay
     (strcat "LAYER-" j "-DIM") 1 "CONTINUOUS")
   (Make_Lay
     (strcat "LAYER-" j "-HID") 6 "HIDDEN2")
   (setq i (1+ i)))
 (princ))
(defun Make_Lay (Nme Col Lt)
 (entmake
   (list
     (cons 0 "LAYER")
     (cons 100 "AcDbSymbolTableRecord")
     (cons 100 "AcDbLayerTableRecord")
     (cons 2 Nme)
     (cons 70 0)
     (cons 62 Col)
     (cons 6 Lt)
     (cons 290 1)
     (cons 370 0))))
Thanks BIGAL & Lee Mac.
Lee Mac, that code is indeed lightning quick. First time I tried it (entering 99) I thought it failed because nothing happened, until I saw that all layers were there. It works great!
While I can still get my head around the first routine, the second one (Make_Lay) gets a bit mysterious to me, but I can use this as a basis for several different layer creation routines.
One question though. We set up our layers using Lineweight: Default, but the layers created using this routine are at 0.00mm. While it's easy to change all layers to Default in the layer pallette, I was wondering if this can be changed in the Make_Lay routine?
Either way, thanks for your help, it's a very useful piece of code :)
Try this, I have also explained each line for you :)
 ;; Define function and Localise Variables
 (initget 7)
 ; Prevents -ve & 0 and user hitting Enter
 (setq x (getint "\nHow Many: ") ; Get Number of Layers
       len (strlen (itoa x)) ; Get String Length of Layer number
       i 1) ; Inititate Counter
 (repeat x  ; Repeat the following
   (setq j (itoa i))
   ; Convert the Counter to a String
     ; While the string is shorter than the length of the No. of layers...
     ;; Pad it with zeros.
   ;; {INVOKE MAKE_LAY}
   (Make_Lay
   (Make_Lay
   (Make_Lay
   (Make_Lay
   (setq i (1+ i)) ; Increment Counter
   ) ; End Repeat
 (princ) ; Exit Cleanly
 ) ; End Function
 (entmake
   (list
     (cons 0 "LAYER") ; Entity Type
     (cons 100 "AcDbSymbolTableRecord") ; Subclass Markers
     (cons 100 "AcDbLayerTableRecord")  ; Subclass Markers
     (cons 2 Nme)  ; Layer Name
     (cons 70 0)   ; Layer Flags (Locked/Frozen etc)
     (cons 62 Col) ; Layer Colour
     (cons 6 Lt)   ; Layer Linetype
     (cons 290 1)  ; Layer to Plot (0 = No, 1 = Yes)
     (cons 370 -3) ; Lineweight enum
     ) ; End list
   ) ; end entmake
 ) ; end function
Thanks Lee Mac, that works perfect.
This bit of code, is there a list of these numbers and values anywhere, documenting what it all means?
I wouldn't have figured out in a million years that the '-3' would have given me Default lineweights :geek:
I didn't look it up, I just set a layer in CAD to Default lineweight and quickly wrote some code to "work it backwards" to see what the enum was.
But for reference, see here.
Lee
When I mention "work it backwards" I mean, retrieve the DXF table for the entity, using code similar to these:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:en [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ent[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ent [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entsel[/color][/b] [b][color=#ff00ff]"\nSelect Object: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] n [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] ent[b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]print[/color][/b] n[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]textscr[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:layen [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] lay tdef[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]snvalid[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]Setq[/color][/b] lay [b][color=RED]([/color][/b][b][color=BLUE]getstring[/color][/b] [b][color=BLUE]t[/color][/b] [b][color=#ff00ff]"\nSpecify Layer: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tdef [b][color=RED]([/color][/b][b][color=BLUE]tblsearch[/color][/b] [b][color=#ff00ff]"LAYER"[/color][/b] lay[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n-- Table Definition --\n"[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] x tdef
       [b][color=RED]([/color][/b][b][color=BLUE]print[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n\n-- LAYER Object -- \n"[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] x [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]tblobjname[/color][/b] [b][color=#ff00ff]"LAYER"[/color][/b] lay[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]print[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]textscr[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n<< Layer not Found >>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:blken [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] blk tdef[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]snvalid[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] blk [b][color=RED]([/color][/b][b][color=BLUE]getstring[/color][/b] [b][color=BLUE]t[/color][/b] [b][color=#ff00ff]"\nSpecify Block Name: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] tdef [b][color=RED]([/color][/b][b][color=BLUE]tblsearch[/color][/b] [b][color=#ff00ff]"BLOCK"[/color][/b] blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n\n-- BLOCK Object -- \n"[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] x [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]tblobjname[/color][/b] [b][color=#ff00ff]"BLOCK"[/color][/b] blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n<< Block not Found >>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
The above should help clarify things :)
