Something I've been working on since yesterday thought i'd throw it out there and see what you guys think.
(defun c:roman ( / stnum stst)
 (if (> (setq stnum (atoi (setq stst (getstring "\n Enter number between 1 (I) and 3999 (MMMCMXCIX): ")))) 0)
   (rn stnum)
   (rnrev stst))
(defun rnrev (st / sl st pout rn prt)
 (setq sl (strlen (setq st (strcase st)))
   pout 0
   rn '(("MMM" . 3000) ("MM" . 2000) ("M" . 1000) ("CM" . 900) ("DCCC" . 800) ("DCC" . 700) ("DC" . 600) ("D" . 500) ("CD" . 400) ("CCC" . 300) ("CC" . 200) ("C" . 100) ("XC" . 90) ("LXXX" . 80) ("LXX" . 70) ("LX" . 60) ("L" . 50) ("XL" . 40) ("XXX" . 30) ("XX" . 20) ("X" . 10) ("IX" . 9) ("VIII" .  ("VII" . 7) ("VI" . 6) ("V" . 5) ("IV" . 4) ("III" . 3) ("II" . 2) ("I" . 1))); /setq
 (while (and (> sl 0)
         (cdr (assoc (substr st 1 1) rn))); /and
   (cond
     ((setq prt  (cdr (assoc (substr st 1 4) rn)))
      (setq st   (substr st 5))); /cond 1
     ((setq prt  (cdr (assoc (substr st 1 3) rn)))
      (setq st   (substr st 4))); /cond 2
     ((setq prt  (cdr (assoc (substr st 1 2) rn)))
      (setq st   (substr st 3))); /cond 3
     ((setq prt  (cdr (assoc (substr st 1 1) rn)))
      (setq st   (substr st 2))); /cond 4
     ); /cond
   (setq rn   (cutlst rn prt)
     sl   (strlen st)
     pout (+ pout prt)); /setq
   ); /while
 (if (= sl 0)
   (princ pout) (princ "Invalid format")); /if
 (princ); silent exit
 ); /defun
(defun rn (gi / sl is gi numlst pout)
 (setq sl (strlen (setq is (itoa gi)))
   numlst (list "1" "2" "3" "4" "5" "6" "7" "8" "9")
   pout "")
 (if (and (> gi 0)
      (< gi 4000))
     (while (> sl 0)
   (cond
     ((= sl 4)
      (setq pout (strcat pout (nth (vl-position (substr is 1 1) numlst) (list "M" "MM" "MMM")))
        sl 3)); /cond1
     ((= sl 3)
      (setq pout (strcat pout (nth (vl-position (substr is 1 1) numlst) (list "C" "CC" "CCC" "CD" "D" "DC" "DCC" "DCCC" "CM")))
        sl 2)); /cond2
     ((= sl 2)
      (setq pout (strcat pout (nth (vl-position (substr is 1 1) numlst) (list "X" "XX" "XXX" "XL" "L" "LX" "LXX" "LXXX" "XC")))
        sl 1)); /cond3
     ((= sl 1)
      (setq pout (strcat pout (nth (vl-position (substr is 1 1) numlst) (list "I" "II" "III" "IV" "V" "VI" "VII" "VIII" "IX")))
        sl 0)); /cond4
     ); /cond
   (setq is (substr is 2))
   ); /while
     (princ pout)
     ); /progn
   (princ "Number Invalid"); else
   ); /if
 ); /defun
(defun cutlst (lst num / z)
 (cond
   ((> num 900)
    (setq num 1000)); /cond 1
   ((> num 90)
    (setq num 100 )); /cond 2
   ((> num 9)
    (setq num 10 ))); /cond 3
 (setq lst (vl-remove-if
         '(lambda (z) (>= (cdr z) num)) lst)); /setq
 ); /defun
Nice one Bill - it works well. Not sure where you'd use it, but great as a novelty :)
Lol yeah i know. It started when i was trying to find out what a certain roman numeral meant. Then i found a converter and I decided to make my own. After many fails I finally got it.
  • 13 years later...
Thanks Commando for sharing this code. I know it has been over a decade since sharing, but it just came in handy for a manual I am working on and intend to use the roman numerals as part of the sheet numbering - I have to come up with a custom function to handle it due to how this manual is built in ACAD.
As I tried the code out, I had an issue with a missing parentheses (it was a quick find) while erroring out on certain value types. The problematic value types are integers greater than nine and possessing zeros in the value, e.g. 108 and 1008. Below [and attached] is the patched version to rid it of that pesky bug.
;;	ROMAN NUMERAL CONVERTERS
;;	ALL credit and source material belongs to the following source:
;;		Commandobill
;;		https://www.cadtutor.net/forum/topic/11354-roman-numeral-converter/
;;	Alterations made from original author and source material are as follows:
;;		- Renamed vast majority most function and symbol names from original source due to OCD and personal practice to
;;		  digest source material.
;;		- Patched the -ROMANNUMERAL function (rn function in original source) to handle zeros when input integer is
;;		  greater than a value of nine (9) and contains zeros, e.g. 108 and 1008.
(defun c:ROMANNUMERALCONVERTER
		intgen
		strgen
	(if (> (setq intgen (atoi (setq strgen (getstring "\n Enter number between 1 (I) and 3999 (MMMCMXCIX): ")))) 0)
		(-ROMANNUMERAL intgen)
		(-ROMANNUMERALREVERSE strgen)
(defun -ROMANNUMERALREVERSE
		strgen
		lenstr
		output
		par
		romnum
		strgen
	(setq
		lenstr (strlen (setq strgen (strcase strgen)))
		output 0
		romnum
			("MMM" . 3000)
			("MM" . 2000)
			("M" . 1000)
			("CM" . 900)
			("DCCC" . 800)
			("DCC" . 700)
			("DC" . 600)
			("D" . 500)
			("CD" . 400)
			("CCC" . 300)
			("CC" . 200)
			("C" . 100)
			("XC" . 90)
			("LXXX" . 80)
			("LXX" . 70)
			("LX" . 60)
			("L" . 50)
			("XL" . 40)
			("XXX" . 30)
			("XX" . 20)
			("X" . 10)
			("IX" . 9)
			("VIII" . 8)
			("VII" . 7)
			("VI" . 6)
			("V" . 5)
			("IV" . 4)
			("III" . 3)
			("II" . 2)
			("I" . 1)
	(while
		(and
			(> lenstr 0)
			(cdr (assoc (substr strgen 1 1) romnum))
		(cond
				(setq par (cdr (assoc (substr strgen 1 4) romnum)))
				(setq strgen (substr strgen 5))
				(setq par (cdr (assoc (substr strgen 1 3) romnum)))
				(setq strgen (substr strgen 4))
				(setq par (cdr (assoc (substr strgen 1 2) romnum)))
				(setq strgen (substr strgen 3))
				(setq par (cdr (assoc (substr strgen 1 1) romnum)))
				(setq strgen (substr strgen 2))
		(setq
			romnum (-CUTLST romnum par)
			lenstr (strlen strgen)
			output (+ output par)
	(if (= lenstr 0)
		(princ output)
		intgen
		intgen
		intstr
		numlst
		output
		lenstr
	(setq
		lenstr (strlen (setq intstr (itoa intgen)))
		output ""
	(if (and (> intgen 0) (< intgen 4000))
			(while (> lenstr 0)
				(cond
						(= lenstr 4)
						(setq
							output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "M" "MM" "MMM")))
							lenstr 3
						(= lenstr 3)
						(setq
							output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "C" "CC" "CCC" "CD" "D" "DC" "DCC" "DCCC" "CM")))
							lenstr 2
						(= lenstr 2)
						(setq
							output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "X" "XX" "XXX" "XL" "L" "LX" "LXX" "LXXX" "XC")))
							lenstr 1
						(= lenstr 1)
						(setq
							output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "I" "II" "III" "IV" "V" "VI" "VII" "VIII" "IX")))
							lenstr 0
				(setq intstr (substr intstr 2))
				;;	START PATCH - alteration to original source material
				(if (= (substr intstr 1 1) "0")
					(while (and (> lenstr 0) (= (substr intstr 1 1) "0"))
						(setq
							lenstr (- lenstr 1)
				;;	END PATCH - alteration to original source material
			(princ output)
(defun -CUTLST
		lst
		num
		z
	(cond
			(> num 900)
			(setq num 1000)
			(> num 90)
			(setq num 100 )
			(> num 9)
			(setq num 10 )
	(setq
		lst
		(vl-remove-if
			'(lambda
				(z)
				(>= (cdr z) num)
			lst
Thanks again CommandoBill! This was an impressive approach to converting Roman Numerals - so simple that it's elegant.
I've took some of my free time to make it prettier (I mean code), and BTW. I don't understand last (vl-remove-if (function (lambda ( z ) (z) ...)) lst), so I removed that (z) ...
;;                Commandobill
(defun c:ROMANNUMERALCONVERTER ( / intgen strgen )
(defun -ROMANNUMERALREVERSE ( strgen / lenstr output par romnum )
  (setq
     output 0
     romnum
      ("MMM" . 3000)
      ("MM" . 2000)
      ("M" . 1000)
      ("CM" . 900)
      ("DCCC" . 800)
      ("DCC" . 700)
      ("DC" . 600)
      ("D" . 500)
      ("CD" . 400)
      ("CCC" . 300)
      ("CC" . 200)
      ("C" . 100)
      ("XC" . 90)
      ("LXXX" . 80)
      ("LXX" . 70)
      ("LX" . 60)
      ("L" . 50)
      ("XL" . 40)
      ("XXX" . 30)
      ("XX" . 20)
      ("X" . 10)
      ("IX" . 9)
      ("VIII" . 8)
      ("VII" . 7)
      ("VI" . 6)
      ("V" . 5)
      ("IV" . 4)
      ("III" . 3)
      ("II" . 2)
      ("I" . 1)
  (while (and
           (> lenstr 0)
         (cond
         (setq
  (if (= lenstr 0)
    (princ output)
(defun -ROMANNUMERAL ( intgen / intstr numlst output lenstr )
  (setq lenstr (strlen (setq intstr (itoa intgen)))
        output ""
      (while (> lenstr 0)
        (cond
            (= lenstr 4)
            (setq output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "M" "MM" "MMM"))))
            (setq lenstr 3)
            (= lenstr 3)
            (setq output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "C" "CC" "CCC" "CD" "D" "DC" "DCC" "DCCC" "CM"))))
            (setq lenstr 2)
            (= lenstr 2)
            (setq output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "X" "XX" "XXX" "XL" "L" "LX" "LXX" "LXXX" "XC"))))
            (setq lenstr 1)
            (= lenstr 1)
            (setq output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "I" "II" "III" "IV" "V" "VI" "VII" "VIII" "IX"))))
            (setq lenstr 0)
                  lenstr (- lenstr 1)
      (princ output)
(defun -CUTLST ( lst num )
  (cond
      (> num 900)
      (setq num 1000)
      (> num 90)
      (setq num 100 )
      (> num 9)
      (setq num 10 )
  (setq lst
    (vl-remove-if
        (>= (cdr z) num)
      lst
