Commandobill Posted June 10, 2009 Posted June 10, 2009 Something I've been working on since yesterday thought i'd throw it out there and see what you guys think. (defun c:roman ( / stnum stst) (if (> (setq stnum (atoi (setq stst (getstring "\n Enter number between 1 (I) and 3999 (MMMCMXCIX): ")))) 0) (rn stnum) (rnrev stst)) ) (defun rnrev (st / sl st pout rn prt) (setq sl (strlen (setq st (strcase st))) pout 0 rn '(("MMM" . 3000) ("MM" . 2000) ("M" . 1000) ("CM" . 900) ("DCCC" . 800) ("DCC" . 700) ("DC" . 600) ("D" . 500) ("CD" . 400) ("CCC" . 300) ("CC" . 200) ("C" . 100) ("XC" . 90) ("LXXX" . 80) ("LXX" . 70) ("LX" . 60) ("L" . 50) ("XL" . 40) ("XXX" . 30) ("XX" . 20) ("X" . 10) ("IX" . 9) ("VIII" . ("VII" . 7) ("VI" . 6) ("V" . 5) ("IV" . 4) ("III" . 3) ("II" . 2) ("I" . 1))); /setq (while (and (> sl 0) (cdr (assoc (substr st 1 1) rn))); /and (cond ((setq prt (cdr (assoc (substr st 1 4) rn))) (setq st (substr st 5))); /cond 1 ((setq prt (cdr (assoc (substr st 1 3) rn))) (setq st (substr st 4))); /cond 2 ((setq prt (cdr (assoc (substr st 1 2) rn))) (setq st (substr st 3))); /cond 3 ((setq prt (cdr (assoc (substr st 1 1) rn))) (setq st (substr st 2))); /cond 4 ); /cond (setq rn (cutlst rn prt) sl (strlen st) pout (+ pout prt)); /setq ); /while (if (= sl 0) (princ pout) (princ "Invalid format")); /if (princ); silent exit ); /defun (defun rn (gi / sl is gi numlst pout) (setq sl (strlen (setq is (itoa gi))) numlst (list "1" "2" "3" "4" "5" "6" "7" "8" "9") pout "") (if (and (> gi 0) (< gi 4000)) (progn (while (> sl 0) (cond ((= sl 4) (setq pout (strcat pout (nth (vl-position (substr is 1 1) numlst) (list "M" "MM" "MMM"))) sl 3)); /cond1 ((= sl 3) (setq pout (strcat pout (nth (vl-position (substr is 1 1) numlst) (list "C" "CC" "CCC" "CD" "D" "DC" "DCC" "DCCC" "CM"))) sl 2)); /cond2 ((= sl 2) (setq pout (strcat pout (nth (vl-position (substr is 1 1) numlst) (list "X" "XX" "XXX" "XL" "L" "LX" "LXX" "LXXX" "XC"))) sl 1)); /cond3 ((= sl 1) (setq pout (strcat pout (nth (vl-position (substr is 1 1) numlst) (list "I" "II" "III" "IV" "V" "VI" "VII" "VIII" "IX"))) sl 0)); /cond4 ); /cond (setq is (substr is 2)) ); /while (princ pout) ); /progn (princ "Number Invalid"); else ); /if (princ) ); /defun (defun cutlst (lst num / z) (cond ((> num 900) (setq num 1000)); /cond 1 ((> num 90) (setq num 100 )); /cond 2 ((> num 9) (setq num 10 ))); /cond 3 (setq lst (vl-remove-if '(lambda (z) (>= (cdr z) num)) lst)); /setq ); /defun Quote
Lee Mac Posted June 10, 2009 Posted June 10, 2009 Nice one Bill - it works well. Not sure where you'd use it, but great as a novelty Quote
Commandobill Posted June 10, 2009 Author Posted June 10, 2009 Not sure where you'd use it, but great as a novelty Lol yeah i know. It started when i was trying to find out what a certain roman numeral meant. Then i found a converter and I decided to make my own. After many fails I finally got it. Quote
FROSTEE3510 Posted March 14, 2023 Posted March 14, 2023 On 6/10/2009 at 12:50 PM, Commandobill said: Lol yeah i know. It started when i was trying to find out what a certain roman numeral meant. Then i found a converter and I decided to make my own. After many fails I finally got it. Thanks Commando for sharing this code. I know it has been over a decade since sharing, but it just came in handy for a manual I am working on and intend to use the roman numerals as part of the sheet numbering - I have to come up with a custom function to handle it due to how this manual is built in ACAD. As I tried the code out, I had an issue with a missing parentheses (it was a quick find) while erroring out on certain value types. The problematic value types are integers greater than nine and possessing zeros in the value, e.g. 108 and 1008. Below [and attached] is the patched version to rid it of that pesky bug. ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % ;; ;; ROMAN NUMERAL CONVERTERS ;; ;; ALL credit and source material belongs to the following source: ;; Commandobill ;; https://www.cadtutor.net/forum/topic/11354-roman-numeral-converter/ ;; ;; Alterations made from original author and source material are as follows: ;; - Renamed vast majority most function and symbol names from original source due to OCD and personal practice to ;; digest source material. ;; - Patched the -ROMANNUMERAL function (rn function in original source) to handle zeros when input integer is ;; greater than a value of nine (9) and contains zeros, e.g. 108 and 1008. ;; ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % (defun c:ROMANNUMERALCONVERTER ( / intgen strgen ) (if (> (setq intgen (atoi (setq strgen (getstring "\n Enter number between 1 (I) and 3999 (MMMCMXCIX): ")))) 0) (-ROMANNUMERAL intgen) (-ROMANNUMERALREVERSE strgen) ) ) (defun -ROMANNUMERALREVERSE ( strgen / lenstr output par romnum strgen ) (setq lenstr (strlen (setq strgen (strcase strgen))) output 0 romnum '( ("MMM" . 3000) ("MM" . 2000) ("M" . 1000) ("CM" . 900) ("DCCC" . 800) ("DCC" . 700) ("DC" . 600) ("D" . 500) ("CD" . 400) ("CCC" . 300) ("CC" . 200) ("C" . 100) ("XC" . 90) ("LXXX" . 80) ("LXX" . 70) ("LX" . 60) ("L" . 50) ("XL" . 40) ("XXX" . 30) ("XX" . 20) ("X" . 10) ("IX" . 9) ("VIII" . 8) ("VII" . 7) ("VI" . 6) ("V" . 5) ("IV" . 4) ("III" . 3) ("II" . 2) ("I" . 1) ) ) (while (and (> lenstr 0) (cdr (assoc (substr strgen 1 1) romnum)) ) (cond ( (setq par (cdr (assoc (substr strgen 1 4) romnum))) (setq strgen (substr strgen 5)) ) ( (setq par (cdr (assoc (substr strgen 1 3) romnum))) (setq strgen (substr strgen 4)) ) ( (setq par (cdr (assoc (substr strgen 1 2) romnum))) (setq strgen (substr strgen 3)) ) ( (setq par (cdr (assoc (substr strgen 1 1) romnum))) (setq strgen (substr strgen 2)) ) ) (setq romnum (-CUTLST romnum par) lenstr (strlen strgen) output (+ output par) ) ) (if (= lenstr 0) (princ output) (princ "Invalid format") ) (princ) ) (defun -ROMANNUMERAL ( intgen / intgen intstr numlst output lenstr ) (setq lenstr (strlen (setq intstr (itoa intgen))) numlst (list "1" "2" "3" "4" "5" "6" "7" "8" "9") output "" ) (if (and (> intgen 0) (< intgen 4000)) (progn (while (> lenstr 0) (cond ( (= lenstr 4) (setq output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "M" "MM" "MMM"))) lenstr 3 ) ) ( (= lenstr 3) (setq output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "C" "CC" "CCC" "CD" "D" "DC" "DCC" "DCCC" "CM"))) lenstr 2 ) ) ( (= lenstr 2) (setq output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "X" "XX" "XXX" "XL" "L" "LX" "LXX" "LXXX" "XC"))) lenstr 1 ) ) ( (= lenstr 1) (setq output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "I" "II" "III" "IV" "V" "VI" "VII" "VIII" "IX"))) lenstr 0 ) ) ) (setq intstr (substr intstr 2)) ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % ;; START PATCH - alteration to original source material (if (= (substr intstr 1 1) "0") (while (and (> lenstr 0) (= (substr intstr 1 1) "0")) (setq intstr (substr intstr 2) lenstr (- lenstr 1) ) ) ) ;; END PATCH - alteration to original source material ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % ) (princ output) ) (princ "Number Invalid") ) (princ) ) (defun -CUTLST ( lst num / z ) (cond ( (> num 900) (setq num 1000) ) ( (> num 90) (setq num 100 ) ) ( (> num 9) (setq num 10 ) ) ) (setq lst (vl-remove-if '(lambda (z) (>= (cdr z) num) ) lst ) ) ) Thanks again CommandoBill! This was an impressive approach to converting Roman Numerals - so simple that it's elegant. Quote
marko_ribar Posted March 14, 2023 Posted March 14, 2023 I've took some of my free time to make it prettier (I mean code), and BTW. I don't understand last (vl-remove-if (function (lambda ( z ) (z) ...)) lst), so I removed that (z) ... ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % ;; ;; ROMAN NUMERAL CONVERTERS ;; ;; ALL credit and source material belongs to the following source: ;; Commandobill ;; https://www.cadtutor.net/forum/topic/11354-roman-numeral-converter/ ;; ;; Alterations made from original author and source material are as follows: ;; - Renamed vast majority most function and symbol names from original source due to OCD and personal practice to ;; digest source material. ;; - Patched the -ROMANNUMERAL function (rn function in original source) to handle zeros when input integer is ;; greater than a value of nine (9) and contains zeros, e.g. 108 and 1008. ;; ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % % (defun c:ROMANNUMERALCONVERTER ( / intgen strgen ) (if (> (setq intgen (atoi (setq strgen (getstring "\n Enter number between 1 (I) and 3999 (MMMCMXCIX): ")))) 0) (-ROMANNUMERAL intgen) (-ROMANNUMERALREVERSE strgen) ) ) (defun -ROMANNUMERALREVERSE ( strgen / lenstr output par romnum ) (setq lenstr (strlen (setq strgen (strcase strgen))) output 0 romnum '( ("MMM" . 3000) ("MM" . 2000) ("M" . 1000) ("CM" . 900) ("DCCC" . 800) ("DCC" . 700) ("DC" . 600) ("D" . 500) ("CD" . 400) ("CCC" . 300) ("CC" . 200) ("C" . 100) ("XC" . 90) ("LXXX" . 80) ("LXX" . 70) ("LX" . 60) ("L" . 50) ("XL" . 40) ("XXX" . 30) ("XX" . 20) ("X" . 10) ("IX" . 9) ("VIII" . 8) ("VII" . 7) ("VI" . 6) ("V" . 5) ("IV" . 4) ("III" . 3) ("II" . 2) ("I" . 1) ) ) (while (and (> lenstr 0) (cdr (assoc (substr strgen 1 1) romnum)) ) (cond ( (setq par (cdr (assoc (substr strgen 1 4) romnum))) (setq strgen (substr strgen 5)) ) ( (setq par (cdr (assoc (substr strgen 1 3) romnum))) (setq strgen (substr strgen 4)) ) ( (setq par (cdr (assoc (substr strgen 1 2) romnum))) (setq strgen (substr strgen 3)) ) ( (setq par (cdr (assoc (substr strgen 1 1) romnum))) (setq strgen (substr strgen 2)) ) ) (setq romnum (-CUTLST romnum par) lenstr (strlen strgen) output (+ output par) ) ) (if (= lenstr 0) (princ output) (princ "Invalid format") ) (princ) ) (defun -ROMANNUMERAL ( intgen / intstr numlst output lenstr ) (setq lenstr (strlen (setq intstr (itoa intgen))) numlst (list "1" "2" "3" "4" "5" "6" "7" "8" "9") output "" ) (if (and (> intgen 0) (< intgen 4000)) (progn (while (> lenstr 0) (cond ( (= lenstr 4) (setq output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "M" "MM" "MMM")))) (setq lenstr 3) ) ( (= lenstr 3) (setq output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "C" "CC" "CCC" "CD" "D" "DC" "DCC" "DCCC" "CM")))) (setq lenstr 2) ) ( (= lenstr 2) (setq output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "X" "XX" "XXX" "XL" "L" "LX" "LXX" "LXXX" "XC")))) (setq lenstr 1) ) ( (= lenstr 1) (setq output (strcat output (nth (vl-position (substr intstr 1 1) numlst) (list "I" "II" "III" "IV" "V" "VI" "VII" "VIII" "IX")))) (setq lenstr 0) ) ) (setq intstr (substr intstr 2)) ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % ;; START PATCH - alteration to original source material (if (= (substr intstr 1 1) "0") (while (and (> lenstr 0) (= (substr intstr 1 1) "0")) (setq intstr (substr intstr 2) lenstr (- lenstr 1) ) ) ) ;; END PATCH - alteration to original source material ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % ;; % % % % % % % % % % % % % % % % % % % % % % % % % % % % ) (princ output) ) (princ "Number Invalid") ) (princ) ) (defun -CUTLST ( lst num ) (cond ( (> num 900) (setq num 1000) ) ( (> num 90) (setq num 100 ) ) ( (> num 9) (setq num 10 ) ) ) (setq lst (vl-remove-if (function (lambda ( z ) (>= (cdr z) num) )) lst ) ) ) 1 Quote
