MR_Zeroeffect Posted June 9, 2009 Posted June 9, 2009 Hello, When you enter list and select a lwpolyline you get a lot of information as; bulge, center, radius, start angle, end angle etc. How can I get this information from a selected object using vba? Is it possible? I know that you can calculate this information, but is there a more simple way? Or does anyone know of some example code? Below you will find the code I got so far: Any help is highly apreciated! // Marcus ThisDrawing.Utility.GetEntity oEnt, vPick, vbCr & "Select object:" If TypeOf oEnt Is AcadLWPolyline Then Dim MyLWPolyline As AcadLWPolyline Set MyLWPolyline = oEnt For lCounter = 0 To lNumberOfCoordinates dNewCoordinates(lCounter) = MyLWPolyline.Coordinates(lCounter) dNewCoordinatesBulge(lCoordpairCounter) = MyLWPolyline.GetBulge(lCoordpairCounter) Next end if Quote
BIGAL Posted June 10, 2009 Posted June 10, 2009 What are you trying to do rather than just getting info re lwpolyline? Someone may have already done it. Quote
MR_Zeroeffect Posted June 15, 2009 Author Posted June 15, 2009 What are you trying to do rather than just getting info re lwpolyline? Someone may have already done it. You are probably right! Im sure someone already have done this, but anyway. Im trying to convert a LWPolyline with arcs, to a polyline whitout arcs (several straight lines instead). And I want to be able to select how many lines (sectors) within the arc to use, depending on the bulge and radie. And I have actually suceeded! Whith a lot of math! Thanks anyway! Quote
