MERGING CORRIDOR SURFACE WITH EXISTING TOPO SURFACE (for rendering composited surfac)
I have completed the designs of a Corridor and generated Corridor Surfaces and Existing Ground Surfaces
My goal is to present a rendered "walk through" of the composited surfaces (Proposed Corridor and Existing Ground) with a "hole" on the Existing Ground Surface where the Corridor Surface "fits in"
(this is the "best" way to review the overall design)
Is there an easy way ?
OR
Do I need to extract the daylight lines from the Corridor and apply this to the Existing Ground Surface ( and "cut-out" the hole from the Existing Ground Surface) ?
Just don't want to spend four hours "cutting the hole" in the Existing Ground Surface
"merge surfaces" command, or do I need to Render the two surfaces at the same time ?
I guess the SURFACE "MASK" command was the command I was looking for.
I took the Daylight Lines from the Corridor and used them as the Inner Boundary to maks the Original Topo Surface
Now I have a "composited" surface to render
However, now everytime I rebuild/edit the Corridor, am I going to have to perform this exercise again ?
OR
Is there a way to LINK to Corridor Daylight Line to the Masked Inner Boundary (of the Original Topo Surface) ?
