i know i'm behind, since we switched to a reactor, but i thought i'd indulge.
Nice solution Alan :D
  • Replies 23
  • Lee Mac
    8
  • Commandobill
    5
  • mdbdesign
    4
  • TimSpangler
    4
Notice: the above does not take into account for the existence of the layers..
TIM - I forgot my call-back arguments...! :shock:
(defun c:MacON ()
 (vl-load-com)
 (if (not lay:react)
     (setq lay:react
       (vlr-command-reactor nil
         (list
           (cons :vlr-commandWillStart 'ChkLay))))
     (princ "\n<< LAYER REACTOR INITIATED >>")))
 (princ))
(defun ChkLay ([b][color=Red]reac args[/color][/b] / lay1 lay2)
 (and (setq lay1 (tblobjname "LAYER" "APPROVED")
            lay2 (tblobjname "LAYER" "PRELIMINARY"))
      (setq lay1 (vlax-ename->vla-object lay1)
            lay2 (vlax-ename->vla-object lay2))
      (cond ((vl-every
               (function
                 (lambda (x) (eq :vlax-true (vla-get-layeron x)))) (list lay1 lay2))
             (vla-put-layeron lay2 :vlax-false))
            ((vl-every
               (function
                 (lambda (x) (eq :vlax-false (vla-get-layeron x)))) (list lay1 lay2))
             (vla-put-layeron lay1 :vlax-true))))
 (princ))
(defun c:MacOFF ()
 (if lay:react
     (vlr-remove lay:react)
     (setq lay:react nil)
     (princ "\n<< LAYER REACTOR DEACTIVATED >>")))
 (princ))
^^ this works now!
Your code reminded me! :D
thought i'd show a less coding option.
Another option from another Alan. :)
(defun c:laysw (/ lay)
 (and (setq lay (tblobjname "LAYER" "APPROVED"))
      (setq lay (entget lay))
      (entmod (subst (cons 62 (- (cdr(assoc 62 lay)))) (assoc 62 lay) lay)))
 (and (setq lay (tblobjname "LAYER" "PRELIMINARY"))
