Need macro or lisp that will keep only one of two layers on.
If layer "APPROVED" is on layer "PRELIMINARY" is off and vice versa.
Use AutoCAD 2002.
Thank you.
  • Replies 23
  • Lee Mac
    8
  • Commandobill
    5
  • mdbdesign
    4
  • TimSpangler
    4
Hmm well i could write a lisp to toggle between the two of them... is that what your looking for?
Yes sir!
That exactly is.
If one is on other is off
Something like this?
(not pretty)
(defun c:laysw (/ lay1 lay2)
 (vl-load-com)
 (and (setq lay1 (tblobjname "LAYER" "APPROVED")
            lay1 (vlax-ename->vla-object lay1))
      (setq lay2 (tblobjname "LAYER" "PRELIMINARY")
            lay2 (vlax-ename->vla-object lay2))
      (cond ((eq :vlax-true (vla-get-layeron lay1))
             (vla-put-layeron lay1 :vlax-false)
             (vla-put-layeron lay2 :vlax-true))
            (t (vla-put-layeron lay2 :vlax-false)
               (vla-put-layeron lay1 :vlax-true))))
 (princ))
Thanks Lee, beer on me.
Perfect.
Perfect.
Make it a Kronenbourg (1664 - not blanc) :D
Trust me Lee what you have is much better than what i was coming up with but you said it wasnt pretty so i cleaned it up a little.
 (vl-load-com)
 (setq lay1 (vlax-ename->vla-object (tblobjname "LAYER" "APPROVED"))
       lay2 (vlax-ename->vla-object (tblobjname "LAYER" "PRELIMINARY")))
 (if (eq :vlax-true (vla-get-layeron lay1))
 (princ))
Lee is there a site explaining what tables there are? i.e. "Blocks" "Layers" etc?
 (vl-load-com)
 (princ))
I prefer mine, as vlax-ename->vla-object will return an error if provided with nil (hence if the layer is not found), wherease mine will stop at the first nil return in the AND statement.
As for what Tables there are, look at the help in the VLIDE on tblnext :)
Except your code error'd out when i ran it with no layer in it. Hmm. perhaps if it was more like this.
 (vl-load-com)
 (and
         lay2 (tblobjname "LAYER" "PRELIMINARY"))
   (setq lay1 (vlax-ename->vla-object lay1)
 (princ))
Thank you for the direction i will have to look into that. Always a pleasure learning from you :D
 (vl-load-com)
 (and
 (princ))
Oh, yes, sorry, got setq's the wrong way round - I knew what I meant :P
I knew what you meant too 8)
This maybe better suited for a reactor. What if someone uses the Layer drop down to turn on a layer, Then they will both be on. With a reactor you can check for the layer status after every command or after a certain command, etc....
just sayin, thats all....
Good point, but with them both on - the code will just default to switching one off.
True but you could still have both on/off. :twisted:
Tim, I tried creating this, but I can't seem to get it too function...
(defun c:MacON ()
 (vl-load-com)
 (if (not lay:react)
     (setq lay:react
       (vlr-command-reactor nil
         (list
           (cons :vlr-commandWillStart 'ChkLay))))
     (princ "\n<< LAYER REACTOR INITIATED >>")))
 (princ))
(defun ChkLay (/ lay1 lay2)
      (cond ((vl-every
               (function
                 (lambda (x) (eq :vlax-true (vla-get-layeron x)))) (list lay1 lay2))
             (vla-put-layeron lay2 :vlax-false))
            ((vl-every
               (function
                 (lambda (x) (eq :vlax-false (vla-get-layeron x)))) (list lay1 lay2))
 (princ))
(defun c:MacOFF ()
 (if lay:react
     (vlr-remove lay:react)
     (setq lay:react nil)
     (princ "\n<< LAYER REACTOR DEACTIVATED >>")))
 (princ))
Hope, can find it in Canada
i know i'm behind, since we switched to a reactor, but i thought i'd indulge.
 (vl-load-com)
 (and
   ) ;_ setq
   ) ;_ setq
   (mapcar
     '(lambda (x y)
        (vla-put-layeron x y)
      ) ;_ lambda
       (list lay1 lay2)
       (list lay2 lay1)
     ) ;_ if
     '(:vlax-false :vlax-true)
   ) ;_ mapcar
 ) ;_ and
) ;_ defun
This seems to work.
Command: LSW to switch layers
if both layers are on or off the when any command is called it will turn on the approved layer.
;;;		Construct the Command Reactors		;
(defun TGS:LayerSwitchReactor  (/)
(or LayerSwitchReactorBE
	(setq LayerSwitchReactorBE (VLR-Command-Reactor "Layer Switch Command Reactor" '((:vlr-commandWillStart . TGS:LS_Begin))))
(or LayerSwitchReactorEn
	(setq LayerSwitchReactorEn (VLR-Command-Reactor "Layer Switch Command Reactor" '((:vlr-commandEnded . TGS:LS_Begin))))
(or LayerSwitchReactorCa
	(setq LayerSwitchReactorCa (VLR-Command-Reactor "Layer Switch Command Reactor" '((:vlr-commandCancelled . TGS:LS_Begin))))
(or LayerSwitchReactorFa
	(setq LayerSwitchReactorFa (VLR-Command-Reactor "Layer Switch Command Reactor" '((:vlr-commandFailed . TGS:LS_Begin))))
;; COMMAND CALLBACK FUNCTIONS                                         ;;
;; Begin event
(defun TGS:LS_Begin (Robject Plist / StatusApproved StatusPrelim LayerApproved LayerPrelim)
;; Get the current properties of each layer
(setq StatusApproved (vla-get-layeron (setq LayerApproved (vlax-ename->vla-object (tblobjname "LAYER" "APPROVED")))))
(setq StatusPrelim (vla-get-layeron (setq LayerPrelim (vlax-ename->vla-object (tblobjname "LAYER" "PRELIMINARY")))))
;; Check the status of each layer
(if (= StatusApproved StatusPrelim)
		(vla-put-layeron LayerApproved ':vlax-true)
		(vla-put-layeron LayerPrelim ':vlax-false)(setq StatusApproved ':vlax-true)
		(setq StatusPrelim ':vlax-false)
;; Quiet Exit
;; MAIN LAYER SWITCH COMMAND                                     ;;
(defun c:LSW (/ StatusApproved StatusPrelim)
(if (= StatusApproved ':vlax-true)
		(vla-put-layeron LayerApproved ':vlax-false)
		(vla-put-layeron LayerPrelim ':vlax-true)
;; Autoload the Layer Switch Reactors
(TGS:LayerSwitchReactor)
;; Quiet Load
(princ "\n	-Layer Switch Reactor Loaded \n")
I have very limited knowledge with reactor so take it for what it is worth
Notice: the above does not take into account for the existence of the layers..
