First time scripting........
I have an attributed block, (two attributes, floating). The attributes are on their own layers. The block can be any desired rotation. The
attributes need to be (0) rotation for ease of reading. I am trying to
use -attedit in a script to rotate all attributes back to zero without
losing existing data in the various tag fields and without changing the
existing rotation value of the block. When the script gets to where it
needs to select all the objects...........the script stops. Select is where I have the problem. Help would be appreciated. See below.
;repetitive attribute editing
;command
-attedit
;edit attributes one at a time?
Y
;enter block name
Hydrant_4inch
;enter attribute tag
HN4IN
;enter attribute value
;select objects
select
Previous
;enter an option (Angle)
A
;enter a value (zero rotation)
0
;enter an option (Next)
N
Make sure this lisp is loaded...then all you have to do is add the lines below to your script:
(defun attstozerorotation (blockname / e ss)
 (vl-load-com)
 (if (setq ss (ssget "_x" (list (cons 0 "INSERT") (cons 2 blockname))))
   (while (setq e (ssname ss 0))
     (foreach att (vlax-invoke (vlax-ename->vla-object e) 'getattributes)
       (vl-catch-all-apply 'vlax-put (list att 'rotation 0.0))
     (ssdel e ss)
;;Lines to add to script...use your block names
;;one block
(attstozerorotation "blockname")
;;many blocks
(mapcar 'attstozerorotation '("blockname1" "blockname2" "blockname3"))
Worked fine thanks, ronjon
:) Glad to help.
