criehle Posted June 4, 2009 Share Posted June 4, 2009 I'm have problems inserting a georeferenced Raster Image. The image will insert and I can view the imagery but it does not georeference the raster as it should because this file is georeferenced. Any ideas? I'm using AutoCAD Map 2009 and the Raster file format is .sid Quote Link to comment Share on other sites More sharing options...
gduplessis Posted March 22, 2016 Share Posted March 22, 2016 Are you using mapiinsert to insert the image? Since it is a .sid file is the .sdw file located in the same folder as the MrSid image file? Quote Link to comment Share on other sites More sharing options...
gS7 Posted October 16, 2020 Share Posted October 16, 2020 Check the units meter or inches Quote Link to comment Share on other sites More sharing options...
