Generating Contours From Corridor Surface
I have been using LDD for many years.
Now I am using 2009 Civil3D to design roadways
I have created Corridors and also a Surface from these Corridors.
No Problem with this.
The last step is to finalize the design by generating contours from the surface.
In LDD it was pretty obvious....select surface...generate contours
How do I do this in Civil 3D 2009 ??
Its all in the surface style... you have to edit the surface style to display the contours.
