Lisp to import coords and code from txt/xls file...
What does this string exactly?
(setq lst (cons (StrBrk nl 44) lst)))
I notice a difference with the previous rutine
44 or 32?
And how can I change it for tab delimited?
  • Replies 75
  • Lee Mac
    32
  • goldy2000
    27
  • tagkelas
    5
  • stevesfr
    3
44 or 32?
This calls the sub-function StrBrk which cuts up the string into sections delimited by the character code specified - i.e. 44 = comma; 32 = space.
So for TAB:
[b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lst [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=RED]([/color][/b]StrBrk nl [b][color=#009900]9[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])
[/color][/b]
Thanks a lot Lee Mac (one more time)
Lee,
again this line
Can we make it a litlle difficult?
How can we make this line with "if" function?
example
strbrk nl 9 (but if do not find "tab") then 44
So in dialog box i can choose either txt or xls file.
Lee,
again this line
example
ooo Dialog Boxes... get you :P
Check my LISP above, posted for JimJones #52. I used an IF statement in there :thumbsup:
Thanks Lee Mac.
I don't have much time right now to check it,
but I will....
Try this for changes to text height and obliquing :)
(defun c:goldy (/ doc spc file nl lst pt)
 (vl-load-com)
 (setq doc (vla-get-ActiveDocument
             (vlax-get-Acad-Object))
       spc (if (zerop (vla-get-activespace doc))
             (if (= (vla-get-mspace doc) :vlax-true) ; Vport
               (vla-get-modelspace doc)
               (vla-get-paperspace doc))
             (vla-get-modelspace doc)))
 (or (tblsearch "LAYER" "TOCKA")
   (vla-add (vla-get-layers doc) "TOCKA"))
 (if (setq file (getfiled "Select Text File"
                       (if *load$file* *load$file* "") "txt" )
     (setq *load$file* file file (open file "r"))
     (while (setq nl (read-line file))
       (setq lst (cons (StrBrk nl 32) lst)))
     (close file)
     (foreach line lst
       (setq pt
         (mapcar 'distof
           (list (cadr line) (caddr line) (cadddr line))))
       (vla-put-layer
         (vla-AddPoint spc (vlax-3D-point pt)) "TOCKA")
       (Make_Text pt (last line) 0.0 "KOD" 0 2 0)  ; CODE
       (Make_Text pt (car line) 0.0 "BROJ TOCKE" 0 0 0)  ; POINT NUMBER
       (Make_Text pt (cadddr line) 0.0 "VISINA" 0 3 (* pi (/ 15 180.)))))  ; Z VALUE
   (princ "\n<!> No File Selected <!>"))
 (princ))
(defun StrBrk (str chrc / pos lst)
 (while (setq pos (vl-string-position chrc str))
   (setq lst (cons (substr str 1 pos) lst)
         str (substr str (+ pos 4))))
 (reverse (cons str lst)))
(defun Make_Text  (pt val rot lay |72 |73 obl)
 (entmake
   (list
     (cons 0 "TEXT")
     (cons 8  lay)
     (cons 10 pt)
     (cons 40 1.6)
     (cons 1  val)
     (cons 50 rot)
     (cons 51 obl)
     (cons 7  (getvar "TEXTSTYLE"))
     (cons 71 0)
     (cons 72 |72)
     (cons 73 |73)
     (cons 11 pt))))
Thanks for this code Lee..works as well..now i have a little request regarding this code i just wanna ask you to removed the "Z" value see the attachment..
thank you and more power..
AA1.txt
Try this Oliver:
 (vl-load-com)
     (close file)
     (foreach line lst
       (setq pt
         (mapcar 'distof
           (list (cadr line) (caddr line) "0.0")))
       (vla-put-layer
       (Make_Text pt (car line) 0.0 "BROJ TOCKE" 0 0 0)))  ; POINT NUMBER
 (princ))
 (entmake
   (list
     (cons 0 "TEXT")
     (cons 8  lay)
     (cons 10 pt)
     (cons 40 1.6)
     (cons 1  val)
     (cons 50 rot)
     (cons 51 obl)
     (cons 71 0)
     (cons 72 |72)
     (cons 73 |73)
     (cons 11 pt))))
thanks a lot Lee..its done..but just a little problem..about point style could fix and also the limits.
thanks.
oliver
I don't understand what you are requesting here?
original display..
fix with drawing limits
original point
with this point style
sorry for my bad english..
oliver
That is just your setting of PDMODE :)
I could add the code to the LISP, its just:
(setvar "PDMODE" )
This can be added anywhere, and its just as easy for you to change it :)
  • 4 years later...
Dear Lee,
I modified your code for my purpose.
I worked fine with my previous work such as DPOINT3 DATA SAMPLE.txt
But It failed with DPOINT3 DATA SAMPLE 1.txt
Colud you possibly help me to rectify?
Thanks,
Miquan
;Draw point from txt data
;Txt data: Point ID,Point X-coord,Point Y-coord,Point Z-coord,Text
;If you want to use tab for delimite data, replace 44 by 32 in code
;http://www.cadtutor.net/forum/showthread.php?37830-Draw-polyline-from-file-coords-excel
(defun c:dp3 (/ doc spc file nl lst pt)
 (vl-load-com)
 (setvar "PDMODE" 35) ; Format point number PDMODE paramater
 (or (tblsearch "LAYER" "S-Notes")
   (vla-add (vla-get-layers doc) "S-Notes"))
     (close file)
     (foreach line lst
       (setq pt
         (mapcar 'distof
       (vla-put-layer
         (vla-AddPoint spc (vlax-3D-point pt)) "S-Notes")
       (Make_Text pt (last line) 0.0 "S-25Text-VN" 0 2 0)  ; CODE
       (Make_Text pt (car line) 0.0 "S-Dim" 0 0 0)  ; POINT NUMBER
       (Make_Text pt (cadddr line) 0.0 "S-Hatch" 0 3 (* pi (/ 15 180.)))))  ; Z VALUE
 (princ))
         str (substr str (+ pos 2))))
 (entmake
   (list
     (cons 0 "TEXT")
     (cons 8  lay)
     (cons 10 pt)
     (cons 40 (getvar "dimtxt")); Height of Text = height of dim text
     (cons 1  val)
     (cons 50 rot)
     (cons 51 obl)
     (cons 71 0)
     (cons 72 |72)
     (cons 73 |73)
     (cons 11 pt))))
  • 2 years later...
Hey Lee, i tried your code and its works like a charm. I want to make a few changes to suit me, i tried but im failing everytime im trying.
I want to make it simplier like POINT,X,Y
Also i can you change the names of the layers back to english?
Thnx in advance
