Change Block Name
Freerefill
Why write a lisp and waste time loading the app.
Just type RENAME into the command line.
problem solved.
  • Replies 43
  • Lee Mac
    18
  • Freerefill
    10
  • David Bethel
    7
  • Commandobill
    2
I deal with drawings containing many 'paste as block' blocks, with random names. Renaming those blocks with the 'rename' command is far from ideal, because the rename dialogue box doesn't show a preview of the block you're renaming. You have to remember the block name before entering the rename dialogue. Simply clicking on the block to rename is a great way to select the block you want to rename.
I never waste time loading a lisp; if I find a useful routine, i add it to a master lisp that's always loaded and always ready to be used.
I spoke to soon though, as this routine redefines only the selected block as a new block, whereas I was hoping it would rename the existing block and all it's instances.
Still cool and with its uses, but not what i need :)
  • 5 months later...
Pls help me with a Auto cad lisp programme which find and replaces attribute values in autocad attributes
eg if the VALUES of different attributes are CAXXXXYYYY001,CAXXXXYYYY002,CAXXXXYYYY003 etc
then
I would like to replace 2nd letter 'C' with letter 'D'
thus it becomes
CDXXXXYYYY001,CDXXXXYYYY002,CDXXXXYYYY003 etc
already got one .exe programme but system security does not allow me to install the programme to my system thats y I badly need a lisp
kindly help
thanks in advance
pls send the code to rajtoms@saudia.com
Merlin Menaco
