Freerefill Posted May 29, 2009 Share Posted May 29, 2009 I always seem to want to tackle the most obscure and pointless problems. Is there a way to change the name of a block using LISP? I gave it a try using two methods, vla-put-name and the entmod/entupd method. Here's my code, nothing too fancy: (defun c:rb( / ) (vl-load-com) (setq ent (car (entsel "\nSelect block: "))) (if (= (cdr (assoc 0 (entget ent))) "INSERT") (progn ;(vlax-put-property (vlax-ename->vla-object ent) "Name" (getstring "\nEnter new name for block: ")) (setq entLst (entget ent)) (setq entLst (subst (cons 2 (getstring "\nEnter new name for block: ")) (assoc 2 entLst) entLst)) (entmod entLst) (entupd ent) ) (princ "\nSelected object is not a block.") ) (princ) ) You'll notice I have both methods in there, one is simply commented out. The vla method returns a key error, the entmod/entupd method doesn't error but it doesn't update the block. The key error seems to be a clue... that the block isn't included in some sort of block reference table..? I've never ran into something like that, so I'm lost. Do I need to add the block to the table, and if so, how? Or is it simply not possible? I was also thinking I could re-create it with entmake if I had to, not sure how that would work. Any ideas? Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 29, 2009 Share Posted May 29, 2009 I tried this, but I too get the same thing: (defun c:test (/ blk tStr) (if (and (setq blk (car (entsel "\nSelect Block: "))) (eq "AcDbBlockReference" (vla-get-ObjectName (setq blk (vlax-ename->vla-object blk)))) (setq tStr (getstring t "\nSpecify New Name: ")) (snvalid tStr)) (if (vlax-property-available-p blk 'Name T) (vla-put-Name blk tStr) (princ "\nCannot Do that!"))) (princ)) Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 29, 2009 Share Posted May 29, 2009 Actually this works: (defun c:test (/ blk tStr) (if (and (setq blk (car (entsel "\nSelect Block: "))) (eq "AcDbBlockReference" (vla-get-ObjectName (setq blk (vlax-ename->vla-object blk)))) (setq tStr (getstring t "\nSpecify New Name: ")) (tblsearch "BLOCK" tStr)) (if (vl-catch-all-error-p (vl-catch-all-apply (function (lambda (x) (vla-put-Name x tStr))) (list blk))) (princ "\nCannot Do that!"))) (princ)) Quote Link to comment Share on other sites More sharing options...
Freerefill Posted May 29, 2009 Author Share Posted May 29, 2009 Actually this works: (defun c:test (/ blk tStr) (if (and (setq blk (car (entsel "\nSelect Block: "))) (eq "AcDbBlockReference" (vla-get-ObjectName (setq blk (vlax-ename->vla-object blk)))) (setq tStr (getstring t "\nSpecify New Name: ")) (tblsearch "BLOCK" tStr)) (if (vl-catch-all-error-p (vl-catch-all-apply (function (lambda (x) (vla-put-Name x tStr))) (list blk))) (princ "\nCannot Do that!"))) (princ)) That's not working for me, Lee. It doesn't error, but it doesn't seem to change the name of the block. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 29, 2009 Share Posted May 29, 2009 That's not working for me, Lee. It doesn't error, but it doesn't seem to change the name of the block. The new Block name must be in the drawing also. From ACAD help: BlockRef: A block reference can be assigned only the name of a valid block definition in the drawing. Assigning a block reference a unique name will not automatically create a new block definition. To create a new block definition, use the Add method to add a new Block object to the Blocks collection. Quote Link to comment Share on other sites More sharing options...
Freerefill Posted May 29, 2009 Author Share Posted May 29, 2009 But if the block name exists, that means the -block- exists, and changing the name of the block to an existing block changes the definition as well.. changing the name of a border block to the name of a title block changes the border block into a title block. That makes sense, but it tells me that if I wanted to keep a block the way it is but simply change the name, I'd have to re-create it from scratch, probably by getting all the entities within it... I wish there was an easier way Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 29, 2009 Share Posted May 29, 2009 But if the block name exists, that means the -block- exists, and changing the name of the block to an existing block changes the definition as well.. changing the name of a border block to the name of a title block changes the border block into a title block. That makes sense, but it tells me that if I wanted to keep a block the way it is but simply change the name, I'd have to re-create it from scratch, probably by getting all the entities within it... I wish there was an easier way Can't have everything the easy way Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 29, 2009 Share Posted May 29, 2009 Making the new block isn't too difficult, here is a LISP a modified from an older one I wrote: [i][color=#990099];; GetBlockEntities by Lee McDonnell [07.05.09][/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] GetBlockEntities [b][color=RED]([/color][/b]Blk Nme [b][color=BLUE]/[/color][/b] tStr[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]tblsearch[/color][/b] [b][color=#ff00ff]"BLOCK"[/color][/b] Blk[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]snvalid[/color][/b] Nme[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entmake[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"BLOCK"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]2[/color][/b] Nme[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]10[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]tblobjname[/color][/b] [b][color=#ff00ff]"BLOCK"[/color][/b] Blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]70[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]entmake[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b]GetObj [b][color=RED]([/color][/b][b][color=BLUE]tblobjname[/color][/b] [b][color=#ff00ff]"BLOCK"[/color][/b] Blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entmake[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"ENDBLK"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]8[/color][/b] [b][color=#ff00ff]"0"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Get Sub-Entities from Table Def[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] GetObj [b][color=RED]([/color][/b]bObj[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] bObj [b][color=RED]([/color][/b][b][color=BLUE]entnext[/color][/b] bObj[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] bObj [b][color=RED]([/color][/b]GetObj bObj[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Test Function[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:test [b][color=RED]([/color][/b][b][color=RED][color=Blue]/[/color][/color][/b][color=Black] old new[/color][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] old [b][color=RED]([/color][/b][b][color=BLUE]getstring[/color][/b] [color=Blue][b]t[/b][/color] [b][color=#ff00ff]"\nOld Block: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] new [b][color=RED]([/color][/b][b][color=BLUE]getstring t[/color][/b] [b][color=#ff00ff]"\nNew Block: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]GetBlockEntities old new[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entmake[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"INSERT"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]2[/color][/b] [color=Black]new[/color][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]10[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getpoint[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Quote Link to comment Share on other sites More sharing options...
Commandobill Posted May 29, 2009 Share Posted May 29, 2009 Can't have everything the easy way I believe you dont know freerefill that well... lol Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 29, 2009 Share Posted May 29, 2009 I believe you dont know freerefill that well... lol Do you guys know each other well? *Just curious* Quote Link to comment Share on other sites More sharing options...
Freerefill Posted May 29, 2009 Author Share Posted May 29, 2009 There is always an easier way!! .... though it was provided by Lee a few weeks ago >.>'' (defun c:rb( / ss blkNam listy ent) (setq ss (ssadd)) (while (not (snvalid (setq blkNam (getstring "\nEnter new name for block: ")))) (princ "\nName not acceptable, please try again.")) (setq listy (GetBlockEntities (cdr (assoc 2 (entget (setq ent (car (entsel)))))))) (foreach forvar listy (entmake (entget forVar)) (setq ss (ssadd (entlast) ss)) ) (command "-block" blknam (list 0 0 0) ss "") (command "-insert" blkNam (cdr (assoc 10 (entget ent))) 1 1 0) (command "erase" ent "") ) (defun GetBlockEntities (Blk / tStr) (if (tblsearch "BLOCK" Blk) (GetObj (tblobjname "BLOCK" Blk)))) (defun GetObj (bObj) (if (setq bObj (entnext bObj)) (cons bObj (GetObj bObj)))) Not a snowballs chance in Heck I'd be able to figure out that GetBlockEntities function on my own. Of course, I'm not sure if any of that is strictly proper, or if there should be more ways to catch errors. It works, though. And yes, he's the Joker, I'm the Batman. EDIT: Looking at it now, I should probably test to see if the insertion point is correct.. maybe transform it into the current UCS.. Quote Link to comment Share on other sites More sharing options...
Commandobill Posted May 29, 2009 Share Posted May 29, 2009 Do you guys know each other well? *Just curious* He sits a cube away... Quote Link to comment Share on other sites More sharing options...
Freerefill Posted May 29, 2009 Author Share Posted May 29, 2009 Double fail! Lee, yours doesn't seem to catch the attributes, though it does create the rest, and mine doesn't create anything if there are attributes. That shall have to be fixed! *workworkwork* Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 29, 2009 Share Posted May 29, 2009 He sits a cube away... Ahhh... I see Double fail! Lee, yours doesn't seem to catch the attributes, though it does create the rest, and mine doesn't create anything if there are attributes. That shall have to be fixed! *workworkwork* Yes, mine will not work for Attributed blocks, but will be quicker making the block than using the "command-call-cop-out" like yours... Quote Link to comment Share on other sites More sharing options...
Freerefill Posted May 29, 2009 Author Share Posted May 29, 2009 Yes, mine will not work for Attributed blocks, but will be quicker making the block than using the "command-call-cop-out" like yours... ... *burned* haha, cheers Lee Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 29, 2009 Share Posted May 29, 2009 ... *burned* haha, cheers Lee Hehe we are such nerds... Quote Link to comment Share on other sites More sharing options...
David Bethel Posted May 29, 2009 Share Posted May 29, 2009 And don't forget about attribute checking. -David Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 29, 2009 Share Posted May 29, 2009 And don't forget about attribute checking. -David David, I can't understand why my posted routine does not entmake the ATTDEF's as well I cycle through the block definition, so the attributes should surely be picked up and created Quote Link to comment Share on other sites More sharing options...
David Bethel Posted May 30, 2009 Share Posted May 30, 2009 Bit 2 has to be set in group 70 in the BLOCK table header. And then 66 must be set to 1 in the INSERT definition. -David Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted May 30, 2009 Share Posted May 30, 2009 Bit 2 has to be set in group 70 in the BLOCK table header. And then 66 must be set to 1 in the INSERT definition. -David Ahh, I see - thanks David Quote Link to comment Share on other sites More sharing options...
