I know that Ctrl+Page Up and Ctrl+Page Down cycles through the Layout Tabs, but is there a way to change the keystroke to something else? I've always got one hand on the mouse and one on the keyboard, so I'm hoping to change one of the two to something like Shift-Tab (as Ctrl-Tab cycles through open Application Windows and Alt-Tab cycles through Windows within a given Application).
You can use this code (not written by me) then set it up in your cui to have 'nextlayout' and 'previouslayout' as keyboard shortcut commands....
;; Created by: Lee Ambrosius
;; Date Written: 12/11/03
;; Includes four commands which can be redefined.
;; NextLayout - Navigates to the right and will wrap around
;;              to the left side once the end is reached
;; PreviousLayout - Navigates to the left and will wrap around
;;                  to the right side once the end is reached
;; FirstLayout - Navigates to the left most tab
;; LstLayout - Navigates to the right most tab
;; Gets a listing of all Layouts in the drawing
(defun Get-Layout-List( / acadObj acDoc acDocLayouts layoutCount loopCount
                         layoutListLocal layoutListSorted layoutName layoutPosition
                         loopCountSorted)
 (vl-load-com)
 (setq acadObj (vlax-get-acad-object))
 (setq acDoc (vlax-get-property acadObj 'ActiveDocument))
 (setq acDocLayouts (vlax-get-property acDoc 'Layouts))
 (setq layoutCount (vlax-get-property acDocLayouts 'Count)
       loopCount 0
       layoutListLocal (list)
       layoutListSorted (list)
 (while (> layoutCount loopCount)
   (setq layoutName (vlax-get-property (vlax-invoke-method acDocLayouts 'Item loopCount) 'Name))
   (setq layoutPosition (vlax-get-property (vlax-invoke-method acDocLayouts 'Item loopCount) 'TabOrder))
   (setq layoutListLocal (append layoutListLocal (list (list layoutPosition layoutName))))
   (setq loopCount (1+ loopCount))
 ;; Resort listing by TabOrder
 (setq layoutCountSorted 0)
 (while (> (length layoutListLocal) (length layoutListSorted))
   (setq loopCountSorted 0)
   (foreach layoutLocation layoutListLocal
       (if (and (= (car layoutLocation) (length layoutListSorted)) (= (car layoutLocation) layoutCountSorted))
           (setq layoutListSorted (append layoutListSorted (cdr (nth loopCountSorted layoutListLocal))))
       (setq layoutCountSorted (1+ layoutCountSorted))
       (setq loopCountSorted (1+ loopCountSorted))
 layoutListSorted
(defun c:nextlayout ( / layout-mem-list layout-list layoutLocation)
 (setq layoutLocation 0)
 (setq layout-list (get-layout-list))
 (setq layout-mem-list (member (getvar "CTAB") layout-list))
 (if layout-mem-list
     (setq layoutLocation (- (length layout-list) (length layout-mem-list)))
   (setq layoutLocation (1+ layoutLocation))
 (if (>= (1+ layoutLocation) (length layout-list))
   (setvar "CTAB" (nth 0 layout-list))
   (setvar "CTAB" (nth (1+ layoutLocation) layout-list))
(defun c:previouslayout ( / layout-mem-list layout-list layoutLocation)
 (if layout-mem-list
   (setq layoutLocation (1- layoutLocation))
 (if (= layoutLocation 0)
   (setvar "CTAB" (nth (1- (length layout-list)) layout-list))
   (setvar "CTAB" (nth (1- layoutLocation) layout-list))
(defun c:FirstLayout ( / layout-list layoutLocation)
 (setvar "CTAB" (nth 0 (get-layout-list)))
(defun c:LastLayout ( / layout-list)
 (setvar "CTAB" (nth (- (length layout-list) 1) layout-list))
  • 2 months later...
;;FirstLayout - Navigates to the left most tab
Command "FirstLayout" doesn't really take to first layout.
It takes you to model space instead.
Is it possible to fix this?
Tnx for help in advance.
I think it could be shortened somewhat...
[i][color=#990099];; Layout Switcher, by Lee McDonnell ~ 06.08.2009[/color][/i]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] lays [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] lst[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vlax-for[/color][/b] lay [b][color=RED]([/color][/b][b][color=BLUE]vla-get-Layouts[/color][/b]
                 [b][color=RED]([/color][/b][b][color=BLUE]vla-get-ActiveDocument[/color][/b]
                   [b][color=RED]([/color][/b][b][color=BLUE]vlax-get-acad-object[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lst [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] lay lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]vla-get-Name[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]vl-sort[/color][/b] lst
     [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]a b[b][color=RED])[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]<[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vla-get-TabOrder[/color][/b] a[b][color=RED])[/color][/b]
              [b][color=RED]([/color][/b][b][color=BLUE]vla-get-TabOrder[/color][/b] b[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:nlay [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] pos lst[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pos [b][color=RED]([/color][/b][b][color=BLUE]1+[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-position[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"CTAB"[/color][/b][b][color=RED])[/color][/b]
                 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] lst [b][color=RED]([/color][/b]lays[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setvar[/color][/b] [b][color=#ff00ff]"CTAB"[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]nth[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]eq[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]length[/color][/b] lst[b][color=RED])[/color][/b] pos[b][color=RED])[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]pos[b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:play [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] pos lst[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pos [b][color=RED]([/color][/b][b][color=BLUE]1-[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]vl-position[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"CTAB"[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]cond[/color][/b] [b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=BLUE]minusp[/color][/b] pos[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]1-[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]length[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b]pos[b][color=RED])[/color][/b][b][color=RED])[/color][/b] lst[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:flay [b][color=RED]([/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setvar[/color][/b] [b][color=#ff00ff]"CTAB"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]nth[/color][/b] [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b]lays[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:llay [b][color=RED]([/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setvar[/color][/b] [b][color=#ff00ff]"CTAB"[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]last[/color][/b] [b][color=RED]([/color][/b]lays[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
I use at work think one. q will bring you one tab rto the right and qq will bring you one tab to the left. the only thing you cant do is, if you are in model space, you cant use qq to go to the last tab in the series. I hope this helps.
(defun c:q (/ ActDoc DocNumb LoCol TabList)
 (setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
 (setq LoCol (vla-get-Layouts ActDoc))
 (vlax-for i LoCol
   (setq TabList (cons    (cons (vla-get-Name i) (vla-get-TabOrder i))
           TabList
 (setq TabList (vl-sort TabList '(lambda (a b) (< (cdr a) (cdr b)))))
 (setq TabList (append TabList (list (car TabList))))
 (setvar "ctab"
     (car (nth (1+    (vl-position
             (assoc (getvar "ctab") TabList)
             TabList
           TabList
(defun c:qq (/ ActDoc DocNumb LoCol TabList)
 (vlax-for i LoCol
           TabList
 (setvar "ctab"
     (car (nth (1-    (vl-position
             TabList
           TabList
Great Lee, Thanks for the code once again.:):D
  • 1 year later...
Anyone know how to do a LT friendly version haha?
I suppose if you can figure out the actual command that coincides with Ctrl+Page Up/Down, then you could macro it in your PGP.
