(defun C:G-()
    (command "-layer" "OFF" "*" "YES" "ON" "G-*" "")
  );end of G-
(defun C:G-ON()
    (command "-layer" "ON" "G-*" "")
Hey we use layer codes starting with G- , R- ETC
I wrote these easy two to isolate the layers starting with G- and to turn on the layers starting with G-
But im having problems with writing the lisp for turning off the layers starting with G- - with allowing for the additional possibility that a G- layer is set to current
any help?
Cheers again:D
(defun Pattern_On_Off(Pattern Mode / St)
 (vl-load-com)
 (vlax-for l(vla-get-Layers
       (vla-get-ActiveDocument
	 (vlax-get-acad-object)))
   (if(wcmatch(vla-get-Name l)Pattern)
     (vla-put-LayerOn l
(if Mode :vlax-true :vlax-false))
     ); end if
   ); end vlax-for
 ); end Pattern_On_Off
Arguments:
Pattern - string with wildcard pattern (for more patterns look function WCMATCH help),
Mode - T- turns layers ON, nil- turns OFF.
For exampe:
(Pattern_On_Off "G-*" nil) - turn of all layers starts with G-
(Pattern_On_Off "G-*" T) turn on all layers starts with G-
  • 4 months later...
Very cool. Do you have a version that prompts you for the pattern and uses that?
> ChrisCMU
I decide to add some lines:
(defun c:lonff(/ cFlag Pat lLst Ans)
 (vl-load-com)
 (while(not cFlag)
    (setq Pat(getstring T "\nSpecify layer name pattern or [All/Help]: "))
  (cond
    ((member Pat '("H" "h" "_H" "_h" "Help" "HELP" "help"))
     (princ "\n             <<< PATTERNS AVAILABLE >>> \n")
     (princ "\n   #      - Matches any single numeric digit.")
     (princ "\n   @      - Matches any single alphabetic character.")
     (princ "\n   .      - Matches any single nonalphanumeric character.")
     (princ "\n   *      - Matches any character sequence, including an ")
     (princ "\n            empty one, and it can be used anywhere in the ")
     (princ "\n            search pattern: at the beginning, middle, or end.")
     (princ "\n   ?      - Matches any single character \n")
     (princ "\n   ~      - If it is the first character in the pattern,")
     (princ "\n            it matches anything except the pattern.")
     (princ "\n   [...]  - Matches any one of the characters enclosed.")
     (princ "\n   [~...] - Matches any single character not enclosed.")
     (princ "\n   -      - Used inside brackets to specify a range.")
     (princ "\n            for a single character.")
     (princ "\n   ,      - Separates two patterns.")
     (princ "\n   `      - Escapes special characters (reads next")
     (princ "\n            character literally).")
     (princ "\n\nPress F2 to close text scren...\n")
     (textscr)
     ); end condition #1
    ((member Pat '("A" "a" "_A" "_a" "All" "ALL" "all"))
     (setq Pat "*" cFlag T)
     ); end condition #2
    ((/= Pat "")
     (setq cFlag T)
     ); end condition #3
    ((= "" Pat)
      (princ "\nEmpty input Quit. ")
      (setq Pat nil cFlag T)
     ); end condition #4
    ); end cond
 ); end while
  (if Pat
     (setq lLst '())
(if(wcmatch(vla-get-Name l)Pat)
   (setq lLst(append lLst(list l)))
  ); end if
); end vlax-for
     (if lLst
  (princ
    (strcat "\n" (itoa(length lLst)) " layers found ")
    ); end princ
  (setq Ans "List")
  (while(or(= Ans "List")(= Ans "Highlight"))
    (initget 1 "ON OFF List Highlight Quit")
    (setq Ans(getkword "\nSelect option [ON/OFF/List/Highlight/Quit] <Quit>: "))
    (cond
      ((= "List" Ans)
       (princ "\nLAYERS LIST: ")
       (princ(strcat "\n"(vla-get-Name(car lLst))))
       (foreach l(cdr lLst)
	 (princ(strcat ", "(vla-get-Name l)))
	 ); end foreach
       ); end condition #1
      ((= "ON" Ans)
       (mapcar '(lambda(l)(vla-put-LayerON l :vlax-true))lLst)
       ); end condition #2
      ((= "OFF" Ans)
       (mapcar '(lambda(l)(vla-put-LayerON l :vlax-false))lLst)
       ); end condition #3
      ((= "Highlight" Ans)
        (sssetfirst nil(ssget "_X"(list(cons 8 pat))))
       ); end condition #4
      (T
       ); end condition #5
      ); end cond
    ); end while
  ); end progn
(princ "\nNothing found! ")
); end if
     ); end progn
   ); end if
 ); end of  c:lonff
Maybe add [... Freeze/Thaw/Lock/Unlock ...]?
Asmi - that works so great - i never said thanks - thanks heaps mate
Works a charm.
  • 1 month later...
There is with additional options http://www.asmitools.com/Files/Lisps/Patlay.html . New program name PATLAY.
impeccable routine. i did notice one issue, it's case sensitive. if you type in "LAYER" and the name is "layer" is says it doesn't exist. i was going to make the change myself and post it, but my vla experience is limited to altering a vla list of layers as vla-objects.
as far as suggestions go (if you don't mind), an isolate and an option to erase everything on a specified layer would be most useful, i know i couldn't live w/o my LX command that will either erase everything on the layer of a picked entity, or the typed in name.
That because layer names is case sensitive. You can create for example three layers "Layer1", "lAYER1" and "layer1". All will works. Ok I will think about it. Maybe make option and store current value in Registry. It possible.
Ok. I can to add Isolate option. But I think erase option isn't need because there is Highlight option. You can highlight layers and use _ERASE command.
Thanks for your ideas, I appreciate your participation. I will try to make that be one of these days. Today my limit of time is exhausted, it is necessary to work.
are you sure about this? if i create a layer called "alan", then try and create a layer called "AlAn" or "aLAn" it will just overwrite the existing layer. i don't think it's case sensitive.
also, if you type -layer off "storm* it will turn off all layers with storm in them, regardless of casing.
good point, i completely forgot about the highlight option.
on a side note, how can you manipulate a vla list of layer names?
You are right. I at all do not know to that I so thought. Thanks for good idea. This non case sensetive version:
;;  PATLAY.LSP - Allows to select group of layers with the help ;;
;;               of wildcard pattern string and to do with them ;;
;;               following actions: On/Off, Lock/Unlock,        ;;
;;               Freeze/Thaw, Highlight (select).               ;;
;;  Command(s) to call: PATLAY                        		;;
;;  Specify wildcard string and do action with layers selected  ;;
;;  THIS PROGRAM AND PARTS OF IT MAY REPRODUCED BY ANY METHOD	;;
;;  ON ANY MEDIUM FOR ANY REASON. YOU CAN USE OR MODIFY THIS	;;
;;  PROGRAM OR PARTS OF IT ABSOLUTELY FREE.                 	;;
;;  THIS PROGRAM PROVIDES THIS PROGRAM 'AS IS' WITH ALL FAULTS	;;
;;  AND SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF		;;
;;  MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE.            ;;
;;  V1.1, 21st Aug 2008, Riga, Latvia                   	;;
;;  © Aleksandr Smirnov (ASMI)                          	;;
;;  For AutoCAD 2000 - 2009 (isn't tested in a next versions)	;;
;;                             http://www.asmitools.com   	;;
(defun c:patlay(/ oldPat cFlag lLst Ans actDoc aName)
 (vl-load-com)
 (if(not laypat:pat)(setq laypat:pat ""))
 (setq oldPat laypat:pat)
 (while(not cFlag)
    (setq laypat:pat(getstring T
	       (strcat "\nLayer name pattern or [Help/Quit] <"
		       laypat:pat ">: ")))
  (cond
    ((member laypat:pat '("H" "h" "_H" "_h" "Help" "HELP" "help"))
     (princ "\n            search pattern at the beginning, middle, or end.")
     (textscr)
     ); end condition #1
    ((member laypat:pat '("Q" "q" "_Q" "_q" "Quit" "QUIT" "quit"))
     (setq cFlag T laypat:pat "")
     ); end condition #2
    ((= laypat:pat "")
     (setq laypat:pat oldPat cFlag T)
     ); end condition #3
    (t
     (setq cFlag T)
     ); end condition #4
    ); end cond
 ); end while
  (if(/= laypat:pat "")
     (setq lLst '()
    actDoc(vla-get-ActiveDocument
    ); end setq
     (vlax-for l(vla-get-Layers actDoc)
(if(wcmatch(strcase(vla-get-Name l))(strcase laypat:pat))
  ); end if
); end vlax-for
     (if lLst
          (princ(strcat "\n>>> Layers found ("(itoa(length lLst))"): "))
    (princ(strcat (vla-get-Name(car lLst))))
   ); end foreach
  (setq Ans "lIst")
  (while(or(= Ans "lIst")(= Ans "Highlight"))
    (initget "On ofF Lock Unlock fReeze Thaw Highlight Quit")
    (setq Ans
	   (getkword
	     "\nSelect option [On/ofF/Lock/Unlock/fReeze/Thaw/Highlight/Quit] <Quit>: "))
    (cond
      ((= "On" Ans)
       ); end condition #2
      ((= "ofF" Ans)
       ); end condition #3
      ((= "Lock" Ans)
       (mapcar '(lambda(l)(vla-put-Lock l :vlax-true))lLst)
       ); end condition #4
      ((= "Unlock" Ans)
       (mapcar '(lambda(l)(vla-put-Lock l :vlax-false))lLst)
       ); end condition #5
      ((= "fReeze" Ans)
       (mapcar '(lambda(l)(if(not(member(vla-get-Name l)
			    (list
			      (vla-get-Name
				(vla-get-ActiveLayer actDoc))
			      "0")))
			    (vla-put-Freeze l :vlax-true)))
	       lLst); end mapcar
       (if(member
	    (setq aName(vla-get-Name(vla-get-Activelayer actDoc)))
		 (mapcar 'vla-get-Name lLst))
	 (princ(strcat "\nCan't freeze active layer '" aName "'! "))
	 ); end if
       ); end condition #6
      ((= "Thaw" Ans)
			    (list
			      (vla-get-Name
			      "0")))
			    (vla-put-Freeze l :vlax-false)))
	       lLst); end mapcar
       (setvar "CMDECHO" 0)
       (command "_.regenall")
       (setvar "CMDECHO" 1)
       ); end condition #6
        (sssetfirst nil(ssget "_X"(list(cons 8 laypat:pat))))
       ); end condition #7
      ((or(not Ans)(= "Quit" Ans))
        (princ "\nQuit LAYPAT ")
       ); end condition #8
      ); end cond
    ); end while
  ); end progn
(princ "\nNo layers found! ")
); end if
     ); end progn
    (setq laypat:pat oldPat)
   ); end if
 ); end of  c:patlay
(princ "\n*** Type PATLAY for wildcard layer actions*** ")
For example (type in command line) get layers collection:
Command: (setq lCol(vla-get-Layers(vla-get-ActiveDocument(vlax-get-acad-object))))
#<VLA-OBJECT IAcadLayers 0765a6bc>
Turn OFF all layers:
Command: (vlax-for l lCol(vla-put-LayerON l :vlax-false))
nil
Turn ON all layers:
Command: (vlax-for l lCol(vla-put-LayerON l :vlax-true))
nil
Use VLAX-FOR or VLAX-MAP-COLLECION functions to loop all collection items and manipulate them. PATLAY creates list of layrs matched to pattern inside VLAX-FOR loop and apply function LAMBDA to change layer state. For example:
will turn ON all layers in 'Lst' list.
Nice work ASMI.
Here is another play toy.
;;  CAB 08.21.08  [ Limited Testing ]  version 3
;;  User pick of layers to remain Thawed, freeze all others
;;  Picked layers turn off as picked, when Enter is pressed
;;  picked layers are thawed & turned on and all others are frozen
;;  modified to allow current layer to be frozen, makes the first
;;  thawed layer current
;;  If a layer in an xref is selected the layer the xref is on can
;;  not be frozen
;;  Layer 0 in an xref will not be frozen
;;  added uiso to restore the previous layer states
(defun c:liso (/ laylst thalst ent lname xrlays)
(vl-load-com)
 ;; get current layer settings
 (defun getlayerdata (doc / lst)
   (vlax-for layObj (vla-get-layers doc)
     (setq lst (cons (list layObj
                           (vla-get-freeze layObj)
                           (vla-get-layeron layObj)
                     lst)))
   lst
 (defun xrefp (ent / elist blist)
   (and
     (setq elist (entget ent))
     (setq blist (entget (tblobjname "BLOCK" (cdr (assoc 2 elist)))))
     (= 4 (logand (cdr (assoc 70 blist)) 4))
 (defun LayerOff (layname doc) ; added for version 3
   (vla-put-LayerOn (vla-item (vla-get-layers doc) layname) :vlax-false)
 (command ".undo" "begin")
 (setq *laysts (getlayerdata (vla-get-activedocument (vlax-get-acad-object)))
       *clayer (getvar "clayer")
 (prompt "\nLayers picked will turn off during selection.")
 (while (setq ent (nentsel "\nPick layers to keep thawed. Enter when done"))
   (setq lname (cdr (assoc 8 (entget (car ent)))))
   (if (vl-position lname xrlays)
     (prompt "\nFlagged xref layer can not be frozen.")
     (if (and (= lname "0") (cadddr ent) (xrefp (last (nth 3 ent))))
       (prompt "\nLayer 0 in xref can not be frozen.")
       (setq thalst (cons lname thalst))
       (LayerOff lname (vla-get-activedocument (vlax-get-acad-object)))
       (if (and (cadddr ent) (xrefp (car (nth 3 ent))))
         (progn    ; save the xref layer
           (setq xrlays (cons (cdr (assoc 8 (entget (last (nth 3 ent))))) xrlays)
                 thalst (cons (car xrlays) thalst)
 (if thalst
     (setq laylst (list (cdr (assoc 2 (tblnext "layer" t))))
     (while (setq lay (cdr (assoc 2 (tblnext "layer"))))
       (if (and lay
                (not (member lay thalst))
                (/= lay clayer)
         (setq laylst (cons lay laylst))
     (if (vl-position *clayer laylst)
       (setvar "clayer" (car thalst))
     (command "._Layer")
     (mapcar '(lambda (x) (command "_f" x)) laylst)
     (command "")
     (command "._Layer")
     (mapcar '(lambda (x) (command "_ON" x)) thalst)
     (command "")
 (command ".undo" "end")
(prompt "\n*-*  Layers Isolate loaded, Enter LayISO to run.  *-*")
;;  restore previous layer settings
(defun c:uiso (/ doc)
 (setq doc    (vla-get-activedocument (vlax-get-acad-object))
       clayer (vla-get-activelayer doc)
 (if *laysts
       (if (and (setq lyrdat (assoc layObj *laysts))
                (not (equal clayer layObj))
           (vla-put-freeze layObj (cadr lyrdat))
           (vla-put-layeron layObj (caddr lyrdat))
           (if (= *clayer (vla-get-name layObj))
             (vla-put-activelayer doc layObj)
     (setq lyrdat (assoc clayer *laysts))
     (if (/= *clayer (vla-get-name (car lyrdat)))
       (vla-put-freeze (car lyrdat) (cadr lyrdat))
     (vla-put-layeron (car lyrdat) (caddr lyrdat))
     (vla-regen doc acactiveviewport)
Thanks, I just updated the routine for a BUG fix.:shock:
So download it again.
> alanjt
There is non case sensitive version with Isolate and Previouos state restore options: http://www.asmitools.com/Files/Lisps/Patlay.html
that is incredible! i hope you didn't see my comments as demands/requests; i was just making suggestions. however, i will most definitely be using this powerhouse of a routine.
