Hi all,
I have some software that creates a .dxf file that I would like to be able to open in autocad. (currently i have tried this with versions 2007 and 2004.
My problem is that while i can open my exported dxf file in any (ive tried 3) free dxf viewer I cannot open it in Autocad.
When i attempt to i get the following error
"invalid or incomplete dxf input -- drawing discarded"
I suspect autocad is being stricter about something in the file that maybe the free viewers just ignore.
I have attached a dxf file example. I would be interested if anyone can open the file and/or shed some light onto where i am going wrong.
many thanks
J
demo.DXF
As you can see at the bottom of the Select File dialog, You can select different types of formats.
Ok, I see what you mean now. Will look into this further.
I opened the dxf in notepad. AutoCAD does not seem to recognize some of the format. What software are you using to create the dxf?
It seems your dxf is missing vital information that AutoCAD requires I would assume. Below are your partial dxf and a dxf in AutoCAD. I just show the begining of the two files for quick reference.
This is your dxf.
     0
SECTION
    2
TABLES
    0
TABLE
    2
LTYPE
  100
AcDbSymbolTable
   70
    1
    0
LTYPE
  100
AcDbSymbolTableRecord
  100
AcDbLinetypeTableRecord
    2
Class Line Style 0
   70
   64
    3
Solid line ________________
   72
   65
   73
    0
   40
    0
    0
LTYPE
  100
  100
    2
Class Line Style 1
   70
   64
    3
Dashed __ __ __ __ __ __ __ __
   72
   65
   73
    2
   40
0.75
   49
0.5
   74
    0
   49
-0.25
   74
    0
    0
LTYPE
  100
  100
    2
Class Line Style 2
This is a typical AutoCAD DXF.
  0
SECTION
 2
HEADER
 9
$ACADVER
 1
AC1015
 9
$ACADMAINTVER
70
   20
 9
$DWGCODEPAGE
 3
ANSI_1252
 9
$INSBASE
10
0.0
20
0.0
30
0.0
 9
$EXTMIN
10
-221.2045081874669
20
-908.198357601954
30
0.0
 9
$EXTMAX
10
3980.540947143398
20
888.6338788328606
30
0.0
 9
$LIMMIN
10
0.0
20
0.0
 9
$LIMMAX
I would look into the software you are using and see if its meant to be compatable with AutoCAD and any special way you would need to save to an AutoCAD dxf.
