Zorg Posted May 19, 2009 Share Posted May 19, 2009 Heres a neat little code that will zoome extents on all your viewports. Enjoy (defun c:ze (/ oldcmdecho vplist curcvport nr vpss ms en x) (setq oldcmdecho (getvar "cmdecho")) (setvar "cmdecho" 0) (setq vplist (mapcar 'car (vports))) (setq curcvport (getvar "cvport")) (if (= (getvar "tilemode") 0) (progn (if (= (setq ms (getvar "cvport")) 1) (command "._mspace") ) (setq vpss (ssget "_x" (list '(-4 . "<AND") '(0 . "VIEWPORT") (cons 410 (getvar "ctab")) '(-4 . "<NOT") '(69 . 1) '(-4 . "NOT>") '(-4 . "AND>") ) ) ) (setq nr 0) (if vpss ; in case there are no viewports (repeat (sslength vpss) (setq en (entget (ssname vpss nr))) (if (and (= 0 (logand 1 (cdr (assoc 90 en)))) ; not perspective (< 0 (cdr (assoc 68 en))) ; on and active (/= 16384 (logand 16384 (cdr (assoc 90 en)))) ; not locked ) (progn (setvar "cvport" (cdr (assoc 69 en))) (command "._zoom" "_e") ) ) (setq nr (+ 1 nr)) ) ) (if (= ms 1) (command "._pspace")) ) (foreach x vplist (setvar "cvport" x) (command "._zoom" "_e") ) ) (setvar "cvport" curcvport) (setvar "cmdecho" oldcmdecho) (princ) ) Z Quote Link to comment Share on other sites More sharing options...
