I’ve been looking for the Edit text command and I’m having no luck. I want to be able to pick more then one text at a time to change. Like I have 6 to change and I pick one after another and then it lets me edit them in the order I picked them.
At my last job we used ETA.
Any help??
oops...... got it!
; EDIT ATTRIBUTED OR TEXT BY SELECTION
(defun C:ETA (/ A B C D E F G H J K L M N )
(graphscr)
; (prompt "\nEdit-TEXT/ATTRIBUTE is loaded... ")
(setq A (ssget) B (sslength A) C 0)
(while (
(setq F (car E))
(setq G (cdr E))
(setq H (car G))
(setq J (cdr H))
(setq K "TEXT")
(setq L "INSERT")
(setq M "DIMENSION")
(setq N "MTEXT")
(if (= J K) (command ".ddedit" D ""))
(if (= J N) (command ".ddedit" D ""))
(if (= J L) (command ".ddatte" D ))
(if (= J M) (prompt
"\n You have picked a dimension YOU MORON...., I only do text or attributes ..."))
(terpri)
(setq C (1+ C)))
Here's mine, if you'd like. It works on Text, MText, Attributes, Dimensions and even text within a block (though, keep in mind, it'll change every instance of the block... for now)
;Super-Edit
;by Mark Mercier
;05-11-09
(defun c:ed( / )(super_edit))
(defun c:at( / )(super_edit))
(defun super_edit( / modEnt dumEnt ent)
 (vl-load-com)
 (while (setq ent (nentsel "\nSelect object: "))
   (if (and ent (or (wcmatch (cdadr (entget (car ent))) "*TEXT") (eq "ATTRIB" (cdadr (entget (car ent))))))
   ; Extract properties of selection and save as list, to modify or replace later if failed
   (setq modEnt (vlax-ename->vla-object (car ent)))
   ; extract properties and create dummy text
   (setq dumEnt (_TextCopy ent))
   ; Clear contents of selected text
   (vla-put-TextString modEnt " ")
   (command "regen")
   ; Edit dummy text
   (command "DDEDIT" (entlast))(command)
   ; once DDEDIT is finished, set modEnt TextString equal to dumEnt
   (if (and (caar (cdddr ent)) (wcmatch (vla-get-ObjectName (vlax-ename->vla-object (caar (cdddr ent)))) "*Dimension"))
     (vla-put-TextOverride (vlax-ename->vla-object (caar (cdddr ent))) (vla-get-TextOverride (vlax-ename->vla-object dumEnt)))
     (vla-put-TextString modEnt (vla-get-TextString (vlax-ename->vla-object dumEnt)))
   ; Delete dummy text
   (command "erase" dumEnt "")
   (command "regen")
(defun _TextCopy(ent / vlaEnt lasEnt return)
 (setq return nil)
 (cond
   ((and (wcmatch (cdadr (entget (car ent))) "TEXT") (not (caar (cdddr ent))))
    (setq return (_TextCopy-TEXT ent))
   ((and (wcmatch (cdadr (entget (car ent))) "MTEXT") (not (caar (cdddr ent))))
    (setq return (_TextCopy-MTEXT ent))
   ((and (wcmatch (cdadr (entget (car ent))) "MTEXT") (eq "INSERT" (cdr (assoc 0 (entget (caar (cdddr ent)))))))
    (setq return (_TextCopy-NESMTEXT ent))
   ((and (wcmatch (cdadr (entget (car ent))) "MTEXT") (eq "DIMENSION" (cdr (assoc 0 (entget (caar (cdddr ent)))))))
    (setq return (_TextCopy-DIMMTEXT ent))
   ((and (wcmatch (cdadr (entget (car ent))) "TEXT") (not (assoc 410 (entget (car ent)))))
    (setq return (_TextCopy-NESTEXT ent))
   ((eq "ATTRIB" (cdadr (entget (car ent))))
    (setq return (_TextCopy-NESATT ent))
 return
 ); Creates exact copy of text/mtext/attribute entity as text/mtext, including blocked text. Return entity if successful or nil if not.
(defun _TextCopy-TEXT(ent / vlaEnt lasEnt)
 (command "TEXT" '(0 0 0) 1 1 "1")
 (setq lasEnt (vlax-ename->vla-object (entlast)))
 (setq vlaEnt (vlax-ename->vla-object (car ent)))
 (vla-put-Layer        lasEnt    (vla-get-Layer            vlaEnt))
 (vla-put-Height        lasEnt    (vla-get-Height            vlaEnt))
 (vla-put-TextString        lasEnt    (vla-get-TextString        vlaEnt))
 (vla-put-Rotation        lasEnt    (vla-get-Rotation        vlaEnt))
 (vla-put-ScaleFactor        lasEnt    (vla-get-ScaleFactor        vlaEnt))
 (vla-put-ObliqueAngle        lasEnt    (vla-get-ObliqueAngle        vlaEnt))
 (vla-put-StyleName        lasEnt    (vla-get-StyleName        vlaEnt))
 (vla-put-Alignment        lasEnt    (vla-get-Alignment        vlaEnt))
 (vla-put-Backward        lasEnt    (vla-get-Backward        vlaEnt))
 (vla-put-Normal        lasEnt    (vla-get-Normal            vlaEnt))
 (vla-put-UpsideDown        lasEnt    (vla-get-UpsideDown        vlaEnt))
 (vla-put-InsertionPoint    lasEnt    (vla-get-InsertionPoint        vlaEnt))
 (vla-put-TextAlignmentPoint    lasEnt    (vla-get-TextAlignmentPoint    vlaEnt))
 (setq return (vlax-vla-object->ename lasEnt))
 return
(defun _TextCopy-MTEXT(ent / vlaEnt lasEnt)
 (command "MTEXT" '(0 0 0) '(1 1 0) "1" "")
 (vla-put-AttachmentPoint    lasEnt    (vla-get-AttachmentPoint    vlaEnt))
 (vla-put-Width        lasEnt    (vla-get-Width            vlaEnt))
 (vla-put-BackgroundFill    lasEnt    (vla-get-BackgroundFill        vlaEnt))
 (vla-put-DrawingDirection    lasEnt    (vla-get-DrawingDirection    vlaEnt))
 (vla-put-LineSpacingDistance    lasEnt    (vla-get-LineSpacingDistance    vlaEnt))
 (vla-put-LineSpacingFactor    lasEnt    (vla-get-LineSpacingFactor    vlaEnt))
 (vla-put-LineSpacingStyle    lasEnt    (vla-get-LineSpacingStyle    vlaEnt))
 return
(defun _TextCopy-NESATT(ent / vlaEnt lasEnt)
 (princ "blah")
 return
(defun _TextCopy-NESTEXT(ent / vlaEnt lasEnt)
 (vla-put-Height        lasEnt    (vlax-make-variant (* (cdr (assoc 42 (entget (caar (cdddr ent))))) (cdr (assoc 40 (entget (car ent))))) vlax-vbDouble))
 (vla-put-ScaleFactor        lasEnt    (vlax-make-variant (* (/ (cdr (assoc 41 (entget (caar (cdddr ent))))) (cdr (assoc 42 (entget (caar (cdddr ent)))))) (cdr (assoc 41 (entget (car ent))))) vlax-vbDouble))
 (vla-put-Rotation        lasEnt    (vlax-make-variant (cdr (assoc 50 (entget (caar (cdddr ent))))) vlax-vbDouble))
 (vla-put-Layer        lasEnt    (vlax-make-variant (cdr (assoc 8 (entget (caar (cdddr ent))))) vlax-vbString))
 (vla-put-InsertionPoint    lasEnt (vlax-3D-point
                    (+ (car (cdr (assoc 10 (entget (caar (cdddr ent)))))) (car (cdr (assoc 10 (entget (car ent))))))
                    (+ (cadr (cdr (assoc 10 (entget (caar (cdddr ent)))))) (cadr (cdr (assoc 10 (entget (car ent))))))
                    (+ (caddr (cdr (assoc 10 (entget (caar (cdddr ent)))))) (caddr (cdr (assoc 10 (entget (car ent))))))))
 (vla-put-TextAlignmentPoint    lasEnt (vlax-3D-point
                    (+ (car (cdr (assoc 10 (entget (caar (cdddr ent)))))) (car (cdr (assoc 11 (entget (car ent))))))
                    (+ (cadr (cdr (assoc 10 (entget (caar (cdddr ent)))))) (cadr (cdr (assoc 11 (entget (car ent))))))
                    (+ (caddr (cdr (assoc 10 (entget (caar (cdddr ent)))))) (caddr (cdr (assoc 11 (entget (car ent))))))))
 return
(defun _TextCopy-NESMTEXT(ent / vlaEnt lasEnt)
 return
(defun _TextCopy-DIMMTEXT(ent / vlaEnt lasEnt)
 (command "copybase" (list 0 0 0) (caar (cdddr ent)) "")
 (command "pasteclip" (list 0 0 0))
 (setq return (entlast))
 return
There's probably a few pieces of code that could be cleaned up, but all in all, it -should- work. It's still a work-in-progress. Let me know how it works, if you use it. I use it myself quite often. ^^
Just a quick one:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:qEdit [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] ss dc$tag bs|Txt nw|Txt[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#ff00ff]"TEXT,MTEXT"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] dc$tag [b][color=RED]([/color][/b][b][color=BLUE]load_dialog[/color][/b] [b][color=#ff00ff]"ACAD"[/color][/b][b][color=RED])[/color][/b]
           bs|Txt [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssname[/color][/b] ss [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]new_dialog[/color][/b] [b][color=#ff00ff]"acad_txtedit"[/color][/b] dc$tag[b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]set_tile[/color][/b] [b][color=#ff00ff]"text_edit"[/color][/b] bs|Txt[b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]action_tile[/color][/b] [b][color=#ff00ff]"text_edit"[/color][/b] [b][color=#ff00ff]"(setq nw|Txt $value)"[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]action_tile[/color][/b] [b][color=#ff00ff]"cancel"[/color][/b] [b][color=#ff00ff]"(exit)"[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]start_dialog[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]function[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]entmod[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]subst[/color][/b]
               [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]1[/color][/b] nw|Txt[b][color=RED])[/color][/b]
                 [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] x[b][color=RED])[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]entget[/color][/b]
         [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]listp[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]unload_dialog[/color][/b] dc$tag[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
oops...... got it!
(graphscr)
(while (
(setq F (car E))
(setq G (cdr E))
(setq H (car G))
(setq J (cdr H))
(setq K "TEXT")
(setq L "INSERT")
(setq N "MTEXT")
(if (= J M) (prompt
(terpri)
(setq C (1+ C)))
as ddedit works on just about everything i changed your code just a little bit
(defun C:ETA (/ A B C D E Z)
 (graphscr)
 (while (< C B)
   (setq D (ssname A C) E (entget D))
   (setq Z (cdadr E))
   (if (member Z '("TEXT" "MTEXT" "INSERT" "DIMENSION")) (command ".ddedit" D ""))
   (terpri)
   (setq C (1+ C)))
I'm sure there was something else i wanted to do with it but i dont remember
Just a quick one:
Hmm... doesnt seem like your style Lee. Trying something new?
