Extrude hole through surface body
Hi all
Can any1 tell me how to extrude a hole through a surface body
Draw down your base and turn into a 3d solid.
Draw your circle on the top face.
click extrude and select the circle and specify your distance.
use "subtract" and select the main body, right click (or enter) then select the cylinder Circle you have extruded.)
sorry my mistake should have stated I am using solidworks
Ahhh, it says autocad in your profile.
Thats cool though.
When you have your base surface start a new sketch and mark points to where you would like your holes to be and then use the hole wizard.
I dont have solidworks here so i cant give you an image.
Im sure Matt will be along soon. He and Jd are the SW gods of CadTutor. lol
ah rite, Thanks very much, I do use AutoCAD mainly but just starting to learn solidworks.
I will give that a go.
Cheers
  joes said:
Hi all
First of all, do you have a surface body or a solid body?
For surface body use a circle to split the surface and then delete face.
For solid body use a circle and extrude with cut option or use hole wizard.
Have you gone through the Help>Tutorials?
If you have a surface body just create a sketch of your circle where you want it(on a plane off of your surface). Use the extruded surface option to extrude your circle as a tube(no wall thickness) and not a solid extrude. Once you have both surface bodies you can use the Trim Surface button. Select your tube as your trim tool, select the remove selection option and click in the center of the tube on your surface(it will highlight). After that i select my "tube" and hide it.
Hi
Thanks for that, not at work at the minute will try that on Monday.
Cheers
Hi
Thanks for that info on Friday it has worked.
