Why don't you use a block with an attribute?
  • Replies 48
  • Rooster
    24
  • Lee Mac
    20
  • ronjonp
    3
  • fuccaro
    2
Posted Images
thanks ron - that's a useful backup way. lee mac's LISP is pretty much doing what I want now though ;)
The trailing zero suppression is controlled by your setting of the system variable "DIMZIN".
I have added a few lines to correct this, measurements should be displayed to two dp.
(defun c:ty  (/ hOff vOff olddim pt)
 (setq hoff 0.2)  ; <<-- Horizontal Offset
 (setq vOff 0.15) ; <<-- Vertical Offset
 (setq olddim (getvar "DIMZIN"))
 (setvar "DIMZIN" 0)
 (if (setq pt (getpoint "\nSelect Point: "))
     (SetBlkTF "ept")
     (entmake (list '(0 . "INSERT")
                    '(8 . "0") ; <<-- Block Layer (String)
                    '(2 . "ept")
                    (cons 10 pt)))
     (Make_Text (polar (polar pt (/ pi 2) vOff) 0 hoff)
       (rtos (cadr pt) 2 2) 0.0)))
 (setvar "DIMZIN" olddim)
 (princ))
(defun Make_Text  (pt val rot)
 (entmake (list '(0 . "TEXT")
                (cons 8 "0") ; <<-- Layer (String)
                (cons 10 pt)
                (cons 40 2.5) ; <<-- Text Height (Real)
                (cons 1 val)
                (cons 50 rot)
                (cons 7 (getvar "TEXTSTYLE"))
                '(71 . 0)
                '(72 . 0) ; 0=left     1=center  2=right
                '(73 . 2) ; 0=baseline 1=bottom  2=middle  3=top
                (cons 11 pt))))
 ; FORCE BLOCK TABLE  (David Bethel)
(defun SetBlkTF  (n)
 (cond ((not (snvalid n))
        (princ "\nInvalid Block Name - " n)
        (exit))
       ((tblsearch "BLOCK" n))
       ((findfile (strcat n ".DWG"))
        (command "_.INSERT" n)
        (command))
       (T ; If all else fails....
        (entmake (list (cons 0 "BLOCK") (cons 2 n) (cons 10 (list 0 0 0)) (cons 70 0)))
        (entmake (list (cons 0 "TEXT")
                       (cons 1 (strcat "BLOCK PLACECARD - " n))
                       (cons 7 (cdr (assoc 2 (tblnext "STYLE" T))))
                       (cons 8 "0")
                       (cons 11 (list 0 0 0))
                       (cons 40 (max 1 (getvar "TEXTSIZE")))
                       (cons 72 4)))
        (entmake (list (cons 0 "ENDBLK") (cons 8 "0")))))
 n)
IMO the attributed block with a field is a much cleaner way to do it. This way you do not have a bunch of text and separate blocks all over the place....and if you move the block the position automatically updates. But to each is own.
Ron
ron - i get what you're saying, but i will use try to adapt this LISP for other functions too which won't include blocks, so this gives me the flexibility i need.
lee - one LAST thing (i hope!): is it possible to add a suffix to the y value? eg. 'm'
Sure, not sure that you wanted a prompt, as it slows things down, so you can alter it via the highlighted section:
(defun c:ty  (/ hOff vOff suff olddim pt)
[b][color=Red]  (setq suff "m")  ; <<-- Suffix[/color][/b]
 (setvar "DIMZIN" 0)
     (SetBlkTF "ept")
                    '(2 . "ept")
                    (cons 10 pt)))
       (strcat (rtos (cadr pt) 2 2) suff) 0.0)))
 (princ))
                (cons 10 pt)
                (cons 1 val)
                (cons 50 rot)
                '(71 . 0)
                (cons 11 pt))))
(defun SetBlkTF  (n)
        (exit))
        (command))
                       (cons 8 "0")
                       (cons 72 4)))
 n)
thanks so much leemac. that all works how i want it to now. i've tried to adapt your LISP for another function that doesn't require a block. however, despite changing what layer i want the text to come in as, it keeps the layer from the EPT LISP that you wrote. what have i got wrong?
(defun c:gh (/ hOff vOff suff olddim pt)
(setq hoff 0.2) ;
(setq vOff 0.15) ;
(setq suff "mN") ;
(setvar "DIMZIN" 0)
(princ))
(cons 8 "GRID") ;
(cons 10 pt)
(cons 40 0.5) ;
(cons 1 val)
(cons 50 rot)
'(71 . 0)
(cons 11 pt))))
n)
** just a quick tip Rooster - enclose your code in
 [/ code] tags (without the space), and it will frame it and retain indentations :thumbsup: **
There were a few brackets in the wrong places, but, other than that, good job.
Would you need the offsets though in this case?
With offsets:
 (setq suff "mN") ; <<-- Suffix
 (setvar "DIMZIN" 0)
 (princ))
                (cons 8 "GRID") ; <<-- Layer (String)
                (cons 10 pt)
                (cons 40 0.5) ; <<-- Text Height (Real)
                (cons 1 val)
                (cons 50 rot)
                '(71 . 0)
                (cons 11 pt))))
Without Offsets:
(defun c:gh  (/ suff olddim pt)
 (setvar "DIMZIN" 0)
   (Make_Text pt (strcat (rtos (cadr pt) 2 2) suff) 0.0))
 (princ))
                (cons 10 pt)
                (cons 1 val)
                (cons 50 rot)
                '(71 . 0)
                (cons 11 pt))))
Hope this helps :)
Lee
thanks a lot lee - the one with the offsets is what i was trying to achieve. which bit do i change to extract the x value rather than the y value?
Hopefully this explains things:
 (setvar "DIMZIN" 0)
              (strcat
                (rtos
             [b][color=Red]     (car pt)  ; car=x  cadr=y  caddr=z[/color][/b]
                  2 2)
                suff)
     0.0))
 (princ))
                (cons 10 pt)
                (cons 1 val)
                (cons 50 rot)
                '(71 . 0)
                (cons 11 pt))))
ok, and lastly (honest!) which part controls the decimal placings? what should i change if i now want to supress the decimal points to leave me just with an integer?
This should spell everything out :D
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:gh  [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] hOff vOff suff olddim pt[b][color=RED])[/color][/b]  [i][color=#990099]; Define Function and Localise Variables[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] hoff [b][color=#009999]0.2[/color][/b][b][color=RED])[/color][/b]  [i][color=#990099]; <<-- Horizontal Offset[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] vOff [b][color=#009999]0.15[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; <<-- Vertical Offset[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] suff [b][color=#ff00ff]"mN"[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; <<-- Suffix[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] olddim [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"DIMZIN"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Store Old DIMZIN Variable[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]setvar[/color][/b] [b][color=#ff00ff]"DIMZIN"[/color][/b] [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b]  [i][color=#990099]; Set to not suppress Decimal Zeros[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] pt [b][color=RED]([/color][/b][b][color=BLUE]getpoint[/color][/b] [b][color=#ff00ff]"\nSelect Point: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; If user Selects a Point...[/color][/i]
   [b][color=RED]([/color][/b]Make_Text  [i][color=#990099]; Call "Make_Text" sub-function[/color][/i]
     [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] pt [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] [b][color=Blue]pi[/color][/b] [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b] vOff[b][color=RED])[/color][/b] [b][color=#009900]0[/color][/b] hoff[b][color=RED])[/color][/b]  [i][color=#990099]; Position Argument[/color][/i]
              [b][color=RED]([/color][/b][b][color=BLUE]strcat[/color][/b]  [i][color=#990099]; Concatenate the following:[/color][/i]
                [b][color=RED]([/color][/b][b][color=BLUE]rtos[/color][/b]  [i][color=#990099]; Convert to String[/color][/i]
                  [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] pt[b][color=RED])[/color][/b]  [i][color=#990099]; car=x  cadr=y  caddr=z[/color][/i]
                  [b][color=#009900]2[/color][/b]  [i][color=#990099]; 1=Sci 2=Dec 3=Eng 4=Arch 5=Frac[/color][/i]
                  [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Number of Decimal Places[/color][/i]
                suff[b][color=RED])[/color][/b] [i][color=#990099]; Add Suffix[/color][/i]
     [b][color=#009999]0.0[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]  [i][color=#990099]; Rotation Argument[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]setvar[/color][/b] [b][color=#ff00ff]"DIMZIN"[/color][/b] olddim[b][color=RED])[/color][/b]  [i][color=#990099]; Restore old DIMZIN Setting[/color][/i]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]  [i][color=#990099]; Exit Cleanly[/color][/i]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] Make_Text  [b][color=RED]([/color][/b]pt val rot[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]entmake[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]list[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]0[/color][/b] [b][color=#ff00ff]"TEXT"[/color][/b][b][color=RED])[/color][/b]  [i][color=#990099]; <<-- Entity Type     (Str)[/color][/i]
                [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]8[/color][/b] [b][color=#ff00ff]"GRID"[/color][/b][b][color=RED])[/color][/b]  [i][color=#990099]; <<-- Layer           (Str)[/color][/i]
                [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]10[/color][/b] pt[b][color=RED])[/color][/b]     [i][color=#990099]; <<-- Insertion Point (Pt)[/color][/i]
                [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]40[/color][/b] [b][color=#009999]0.5[/color][/b][b][color=RED])[/color][/b]    [i][color=#990099]; <<-- Text Height     (Real)[/color][/i]
                [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]1[/color][/b] val[b][color=RED])[/color][/b]     [i][color=#990099]; <<-- Text String     (Str)[/color][/i]
                [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]50[/color][/b] rot[b][color=RED])[/color][/b]    [i][color=#990099]; <<-- Rotation        (Real)[/color][/i]
                [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]7[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=#ff00ff]"TEXTSTYLE"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; <<-- Text Style (Str)[/color][/i]
                [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]71[/color][/b] . [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b]        [i][color=#990099]; 0=normal   2=Backward   4=Upside-Down[/color][/i]
                [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]72[/color][/b] . [b][color=#009900]0[/color][/b][b][color=RED])[/color][/b]        [i][color=#990099]; 0=left     1=center     2=right[/color][/i]
                [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#009900]73[/color][/b] . [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b]        [i][color=#990099]; 0=baseline 1=bottom     2=middle 3=top[/color][/i]
                [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]11[/color][/b] pt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]  [i][color=#990099]; Alignment Point      (Pt)[/color][/i]
hehehe - that's what i need. thanks for all your help lee - that's awesome :)
No problem - if you still have any questions about any part of the code, just ask :)
ok, you did say ask! is this the bit i change to change to rotation of the text? i want text rotated 90degrees now....
EDIT: Nevermind - i've done it now. i changed the above to 1.57 (90deg in radians) and i have it now. perfect :)
ok - i now have one small problem. if i run GH.LSP it works fine. if i open a new drawing and run EPT.LSP (the one you called TY) that also works fine. but if i run one after the other in the same drawing, the layers don't change. eg, if i run GH and then afterwards i run EPT, the text from EPT is still in my grid layer. what is stopping EPT from changing the layer to what it should be? The text height also doesn't update.....
OK, I have included the layer as an argument now, - just in case the sub-function was causing the problem.
Also, you can now specify the angle in Degrees :)
     [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]polar[/color][/b] pt [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] pi [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b] vOff[b][color=RED])[/color][/b] [b][color=#009900]0[/color][/b] hoff[b][color=RED])[/color][/b]  [i][color=#990099]; Position Argument[/color][/i]
       [b][color=#009999]0.0[/color][/b]     [i][color=#990099]; Rotation Argument (Deg)[/color][/i]
     [b][color=#ff00ff]"GRID"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]  [i][color=#990099]; Layer Argument[/color][/i]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] Make_Text  [b][color=RED]([/color][/b]pt val rot lay[b][color=RED])[/color][/b]
                [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]8[/color][/b] lay[b][color=RED])[/color][/b]                  [i][color=#990099]; <<-- Layer           (Str)[/color][/i]
                [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] [b][color=#009900]50[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]*[/color][/b] pi [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] rot [b][color=#009999]180.[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; <<-- Rotation        (Real)[/color][/i]
ok, and presumably i will need to do something similar to the first LISP?
EDIT: sorted that problem too now. i don't think it liked having a sub-function with the same name in both LISPS.
Just going back to the first LISP with the block: i have the text coming in in the layer that i want, but the block is coming in in layer 0 - how can i get the block to go into the same layer as the text?
