Complex Solids
  Pocket said:
Elaborate on this command?
AutoCAD 2007 or later.
For elaboration see the tutorials in my signature.
  • Replies 30
  • SilverTiger
    8
  • chrisdarmanin
    4
  • SLW210
    4
  • PS_Port
    3
Posted Images
Ok, you guys are getting into areas of CAD that I honestly don't know enough about. I've been using CAD since '97 but have never had the need to twist anything until I got into designing ships (recently). What is a lisp command and what does it do? Also, another complex solid question: Does 2007 have the option of REVOLVING an object, but on an elliptical path that stretches the pline to match as it is revolved? If so, can it be done in 2005?
Here's what I'm trying to draw (look at the panels on the rams on eahc side of the fuselage, as well as the power systems located adjacent to the rams on top of each j-wing (has five panels that have a slight twist):
Yeah, I tried that. It ends up extruding the profile I created and, if the object is outside the path, it leaves ahole in the center; and if the object is on the inside of the path, the profile intersects itself. I'll try to post some shots.:)
Profile of object to be revolved and the elliptical path:
Left: Inside Path
Right: Outside path
Extruded objects
Left: Intersects itself
Right: Leaves a hole
What I want to do is actually REVOLVE the object but have the profile stretched or contracted from the axis to the elliptical path as it is being revolved.
Appears to me that you really need to upgrade to at least 2007, so you will have the LOFT and Sweep options available.
I guess I have to. But in the meantime I guess I'll try to learn that lisp thing for the surface meshes.:)
3ds max seems better for that job:Do:)
My goodness...that M2S autolisp just became my best friend!!:)
  • 9 months later...
Finally!!!! Thx guys for all your help! :) You made it happen.
