Is there a quick 'n simple way to open a Revit *.rfa file in "vanilla" AutoCAD? :unsure:
Perhaps somehow, someone might be able to convert this *.rfa file to a *.dxf or *.dwg file for me. I have AutoCAD '05 and '07.
"Invalid File", sorry couldn't post. Back to the study hall! :glare:
  • 3 months later...
Guest opqr148
这是新*的空白文*52,可以在ubb可视化编辑器*,添*和修改文*内容。
  • 1 month later...
Quickest way is to export the revit file to a dwg.
You sould be able to export it back to Acad 2000, 2004, 2007 & 2010 if you need to (from Revit 2010 anyway).
Got ot he big R (top Left of screen)
Export / Cad Formats / Dwg
There is an export file where you can set up your layers to look lie your traditional cad file. Takes a bit of time but is worth it.
Hope this helps
