flowerrobot Posted May 12, 2009 Posted May 12, 2009 Ive being using ACad Mecanical for quite a while.But leaving it alone do to its unstable features. It has a niffty feature tho, For blocks Where when you rededit close, you have an opertunity to rename the block and/ or change base point. I wish to replicate this, for now with just an extra button on the refedit toolbar.So 1. Can you ,with a reator, pause a command, and run a routine(dcl box)? So that When you hit refclose, It will put up with this box, before Closing. I am trying to get a copy of all enities in a block, 2.How do i get this selection set? that will select the enities only in the block? I was going to use "enselnp",But that will get what was in the block, not what currently is in it. aka new lines and circles. 3.Would i just simple copy this to the clipboard? If i did this, 4. how would i get these entities, (entlast) pick's the last item, not the entire selection.(did think paste as block then rename, but how would i copy with basepoint, while in refedit?, Should i remove out of block, copy with base point, & disregard changes?) So that i can the create the block with the new point(if changed) Or/and new name. Would do this with a normal block command. Or even better 5.Does any one have some thing like this or 6.Does any one know how to read autocads main files, to extract this list? Thanks help for any help/suggestions. Quote
Lee Mac Posted May 12, 2009 Posted May 12, 2009 This may help get you started, returns a list of Entities (enames), that make up a block: [i][color=#990099];; GetBlockEntities by Lee McDonnell [07.05.09][/color][/i] [i][color=#990099];; ARGS:[/color][/i] [i][color=#990099];; Blk ~ Block Name [str][/color][/i] [i][color=#990099];; RETURN:[/color][/i] [i][color=#990099];; List of Entities (Enames)[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] GetBlockEntities [b][color=RED]([/color][/b]Blk [b][color=BLUE]/[/color][/b] tStr[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]tblsearch[/color][/b] [b][color=#ff00ff]"BLOCK"[/color][/b] Blk[b][color=RED])[/color][/b] [b][color=RED]([/color][/b]GetObj [b][color=RED]([/color][/b][b][color=BLUE]tblobjname[/color][/b] [b][color=#ff00ff]"BLOCK"[/color][/b] Blk[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [i][color=#990099]; Get Sub-Entities from Table Def[/color][/i] [b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] GetObj [b][color=RED]([/color][/b]bObj[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] bObj [b][color=RED]([/color][/b][b][color=BLUE]entnext[/color][/b] bObj[b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cons[/color][/b] bObj [b][color=RED]([/color][/b]GetObj bObj[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] Quote
flowerrobot Posted May 12, 2009 Author Posted May 12, 2009 Lee, Will that not return what is in a block, aka not the current block, Because if im changing the name, i dont want what ive done in my current block to be saved as its current name. thanks for the input Quote
Lee Mac Posted May 12, 2009 Posted May 12, 2009 Lee, Will that not return what is in a block, aka not the current block, Because if im changing the name, i dont want what ive done in my current block to be saved as its current name. thanks for the input This will return the entities that make up the block definition in the block table. I'm not really sure of your requests. Quote
flowerrobot Posted May 15, 2009 Author Posted May 15, 2009 Yes, It will. But it will returns what is saved, correct? What im after is what is currently in the block, As in, You enter a block, draw a line, that line is not part of that block till i save the block. i want to select that line as well as every thing eles in the block, before i save it. So that i can Not save/but close it, and use those items to make a new block. Are you with me? I know i suck at this explaining thing. regards Flower Quote
The Buzzard Posted May 15, 2009 Posted May 15, 2009 flowerrobot, Give the attached program a try. It also returns lists of the entities you select, However to make the block refer to my program on the same thread that I helped you with the images. See link below. Good Luck http://www.cadtutor.net/forum/showthread.php?t=34891 PDXF.LSP Quote
The Buzzard Posted May 15, 2009 Posted May 15, 2009 flowerrobot, Attached is a much simpler program that makes its own blocks. You can use this for a reference to get started. The lists created from the program above can be used to make your block reference.The attached program was made with the program in the previous post. It has only three blocks in it of different shapes with attributes just to keep it simple to learn. Good Luck SL.zip Quote
