socacidan Posted September 26, 2023 Share Posted September 26, 2023 On 1/17/2019 at 1:39 PM, marko_ribar said: Here is that code without BBCode Tags : (defun c:mt (/ cEnt mEnt) (if (and (setq cEnt (car (nentsel "\nSelect Source Text: "))) (member (cdr (assoc 0 (entget cEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (progn (redraw cEnt 3) (while (and (setq mEnt (car (nentsel "\nSelect Destination Text: "))) (member (cdr (assoc 0 (entget mEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (entmod (subst (assoc 1 (entget cEnt)) (assoc 1 (entget mEnt)) (entget mEnt)))) (redraw cEnt 4)) (princ "\n<!> Incorrect Selection <!>")) (princ)) (defun c:mt2 (/ cEnt mEnt sLst) (if (and (setq cEnt (car (nentsel "\nSelect Source Text: "))) (member (cdr (assoc 0 (entget cEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (progn (redraw cEnt 3) (if (setq ss (ssget "_X" '((-4 . "<NOT") (0 . "TEXT,MTEXT,INSERT") (-4 . "NOT>")))) (mapcar '(lambda (x) (redraw x 2)) (setq sLst (mapcar 'cadr (ssnamex ss))))) (while (and (setq mEnt (car (nentsel "\nSelect Destination Text: "))) (member (cdr (assoc 0 (entget mEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (entmod (subst (assoc 1 (entget cEnt)) (assoc 1 (entget mEnt)) (entget mEnt))))) (princ "\n<!> Incorrect Selection <!>")) (command "_regenall") (princ)) (defun c:mt3 (/ cEnt ss) (vl-load-com) (if (and (setq cEnt (car (nentsel "\nSelect Source Text: "))) (member (cdr (assoc 0 (entget cEnt))) '("TEXT" "MTEXT" "ATTRIB"))) (progn (redraw cEnt 3) (if (setq ss (ssget '((0 . "TEXT,MTEXT")))) (foreach x (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) (entmod (subst (assoc 1 (entget cEnt)) (assoc 1 (entget x)) (entget x)))))) (princ "\n<!> Incorrect Selection <!>")) (command "_regenall") (princ)) HTH., M.R. Hello, Is possible to have this lisp to make also -match field to field - and - match text, mtext to field- ? Quote Link to comment Share on other sites More sharing options...
