  On 12/21/2022 at 3:17 AM, BIGAL said:
I use this one by you Lee. It is used where the text is RL 123.45
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  s - String to process                                     ;;
;;  Returns:  List of numerical values found in string.       ;;
(defun LM:ParseNumbers ( s )
    (lambda ( l )
      (read
        (strcat "("
          (vl-list->string
            (mapcar
              (function
                (lambda ( a b c )
                  (if
                    (or
                      (< 47 b 58)
                      (and (= 45 b) (< 47 c 58) (not (< 47 a 58)))
                      (and (= 46 b) (< 47 a 58) (< 47 c 58))
                    b 32
              (cons nil l) l (append (cdr l) (list nil))
    (vl-string->list s)
(setq datum (car (LM:ParseNumbers (cdr (assoc 1 (entget (car (entsel "\nPick datum text"))))))))
Expand
How can I utilise this lisp in my situation?
  On 12/20/2022 at 5:09 PM, Lee Mac said:
Have you tried the program I have posted here?
Expand
Hi Lee Mac
Yes I have tried and its really good, but how can I adjust lisp to show 2 decimal places? example: to show 138.20 and not 138.2 or just 138
Edited by Paulsub
  On 1/13/2023 at 10:15 AM, Paulsub said:
Hi Lee Mac
Expand
Change these lines:
                                       (if (and (= 'int (type x)) (= 'int (type *inc*)))
                                           (itoa (+ x *inc*))
                                           (if (member (type x) '(int real))
                                               (rtos (+ x *inc*) 2)
                                               x
To:
                                           (rtos (+ x *inc*) 2 2)
                                           x
  On 1/13/2023 at 1:34 PM, Lee Mac said:
Change these lines:
                                           (itoa (+ x *inc*))
                                               x
To:
                                           x
Expand
For some reason I am getting error in cad
error: extra right paren on input.
                               (function
                                   (lambda ( x )
                                               x
  On 1/13/2023 at 3:47 PM, Lee Mac said:
That error implies that you have one too many closing parentheses.
Expand
;; Text Increment  -  Lee Mac
;; Increments numerical data found in a selection of Text or MText
;; objects by a value specified by the user.
(defun c:txtinc ( / e i l s x )
   (if (null *inc*)
       (setq *inc* 1.0)
   (if (setq i (getreal (strcat "\nSpecify Increment <" (rtos *inc* 2) ">: ")))
       (setq *inc* i)
   (if (equal 0.0 (rem *inc* 1) 1e-8)
       (setq *inc* (fix *inc*))
   (if (setq s (ssget "_:L" '((0 . "TEXT,MTEXT") (1 . "*#*"))))
       (repeat (setq i (sslength s))
           (setq e (entget (ssname s (setq i (1- i))))
                 x (assoc 1 e)
           (entmod
               (subst
                   (cons 1
                       (apply 'strcat
                           (mapcar
                               (function
                                   (lambda ( x )
                                           x
                               (LM:splitstring (cdr x))
                   x e
;; Split String  -  Lee Mac
;; Splits a string into a list of text and numbers
(defun LM:splitstring ( s )
       (lambda ( l )
           (read
               (strcat "("
                   (vl-list->string
                       (apply 'append
                           (mapcar
                               (function
                                   (lambda ( a b c )
                                       (cond
                                           (   (= 92 b)
                                               (list 32 34 92 b 34 32)
                                           (   (or (< 47 b 58)
                                               (list b)
                                           (   (list 32 34 b 34 32))
       (vl-string->list s)
Hi Lee, now i am getting error: malformed list on input.
Lee, I would need to decrease cover level number by invert. For example: CL136.80  and IL1.20 I would like to get result 135.60 . Is there a way to change lines to decrease number instead of increase?
Thank you for your effort helping.
Edited by Paulsub
What is problem you need to pick 2 text and then can parse the number val and add or subtract.
   (if (null *inc*)
       (setq *inc* 1.0)
       (setq *inc* i)
                 x (assoc 1 e)
           (entmod
               (subst
                   (cons 1
                       (apply 'strcat
                           (mapcar
                               (function
                                   (lambda ( x )
                                           x
                   x e
       (lambda ( l )
           (read
               (strcat "("
                   (vl-list->string
                       (apply 'append
                           (mapcar
                               (function
                                   (lambda ( a b c )
                                       (cond
                                           (   (= 92 b)
                                           (   (or (< 47 b 58)
                                               (list b)
       (vl-string->list s)
Expand
You were missing two closing parentheses - try this:
   (if (null *inc*)
       (setq *inc* 1.0)
       (setq *inc* i)
                 x (assoc 1 e)
           (entmod
               (subst
                   (cons 1
                       (apply 'strcat
                           (mapcar
                               (function
                                   (lambda ( x )
                                           x
                   x e
       (lambda ( l )
           (read
               (strcat "("
                   (vl-list->string
                       (apply 'append
                           (mapcar
                               (function
                                   (lambda ( a b c )
                                       (cond
                                           (   (= 92 b)
                                           (   (or (< 47 b 58)
                                               (list b)
       (vl-string->list s)
Expand
Specify a negative increment.
   (if (null *inc*)
       (setq *inc* 1.0)
       (setq *inc* i)
                 x (assoc 1 e)
           (entmod
               (subst
                   (cons 1
                       (apply 'strcat
                           (mapcar
                               (function
                                   (lambda ( x )
                                           x
                   x e
       (lambda ( l )
           (read
               (strcat "("
                   (vl-list->string
                       (apply 'append
                           (mapcar
                               (function
                                   (lambda ( a b c )
                                       (cond
                                           (   (= 92 b)
                                           (   (or (< 47 b 58)
                                               (list b)
       (vl-string->list s)
Expand
Lee, thank you for coming back to me and trying to help.
I am not getting error now, but still nothing changed and I am getting just one decimal palace ( zero not showing)
Also I have tried to specify a negative increment as you suggested. But i am getting negative sign next to number, is there a way for lisp to exclude and don't show it within text?
image attached for review.
Thank you
Set DIMZIN = 0 to retain trailing zeros.
Where the negative is concerned, surely to obtain 135.6 from 1.2 you would need to specify an increment of +134.4?
Expand
Thank you Lee Mac,  DIMZIN=0 fixed issue with trailing zeros.
Edited by Paulsub
  • 2 months later...
  On 5/11/2009 at 11:17 AM, Lee Mac said:
Three options for you :)
*Just thought I'd write my own versions...* :P
Let me know which one you like best :)
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:mt  [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] cEnt mEnt[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] cEnt [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]nentsel[/color][/b] [b][color=#ff00ff]"\nSelect Source Text: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
          [b][color=RED]([/color][/b][b][color=BLUE]member[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]0[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] cEnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                  [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=#ff00ff]"TEXT"[/color][/b] [b][color=#ff00ff]"MTEXT"[/color][/b] [b][color=#ff00ff]"ATTRIB"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]progn[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]redraw[/color][/b] cEnt [b][color=#009900]3[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]while[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]and[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] mEnt [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]nentsel[/color][/b] [b][color=#ff00ff]"\nSelect Destination Text: "[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                 [b][color=RED]([/color][/b][b][color=BLUE]member[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]cdr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]0[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] mEnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]entmod[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]subst[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] cEnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                      [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] mEnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                      [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] mEnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]redraw[/color][/b] cEnt [b][color=#009900]4[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
   [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b] [b][color=#ff00ff]"\n<!> Incorrect Selection <!>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:mt2  [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] cEnt mEnt sLst[b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=#ff00ff]"_X"[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=#009900]-4[/color][/b] . [b][color=#ff00ff]"<NOT"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#ff00ff]"TEXT,MTEXT,INSERT"[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=#009900]-4[/color][/b] . [b][color=#ff00ff]"NOT>"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=BLUE]lambda[/color][/b] [b][color=RED]([/color][/b]x[b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]redraw[/color][/b] x [b][color=#009900]2[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] sLst [b][color=RED]([/color][/b][b][color=BLUE]mapcar[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]cadr[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]ssnamex[/color][/b] ss[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                      [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] mEnt[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]command[/color][/b] [b][color=#ff00ff]"_regenall"[/color][/b][b][color=RED])[/color][/b]
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:mt3  [b][color=RED]([/color][/b][b][color=BLUE]/[/color][/b] cEnt ss[b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b]
     [b][color=RED]([/color][/b][b][color=BLUE]if[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]setq[/color][/b] ss [b][color=RED]([/color][/b][b][color=BLUE]ssget[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=RED]([/color][/b][b][color=RED]([/color][/b][b][color=#009900]0[/color][/b] . [b][color=#ff00ff]"TEXT,MTEXT"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
       [b][color=RED]([/color][/b][b][color=BLUE]foreach[/color][/b] x  [b][color=RED]([/color][/b][b][color=BLUE]vl-remove-if[/color][/b] [b][color=DARKRED]'[/color][/b][b][color=BLUE]listp[/color][/b]
                        [b][color=RED]([/color][/b][b][color=BLUE]assoc[/color][/b] [b][color=#009900]1[/color][/b] [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                        [b][color=RED]([/color][/b][b][color=BLUE]entget[/color][/b] x[b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
Expand
Thank you for this Mr. Lee!
How about if I also wanted not only to match the text but also match the match prop of the source text (specifically the color of the source text)? Could you please show me the way :(
Edited by AeJay
If you look into the ssget filters (62 . 4) add  62 is dxf, 4 is color  so add (cons 62 4) or (cons 62 laycol)
Expand
HI, which of the 3 examples provided by Lee would you be referring to do this to?
The example I posted applies to most code where Ssget is used and you can have multiple filters applied.
Examples
Object
Object + Layer
Object +  Layer + Color
Object + Layer + Color + Linetype
Examples
Object
Object + Layer
Expand
Could you please teach me how to do it for this code?
(defun c:mt3  (/ cEnt ss)
 (vl-load-com)
 (if (and (setq cEnt (car (nentsel "\nSelect Source Text: ")))
          (member (cdr (assoc 0 (entget cEnt)))
                  '("TEXT" "MTEXT" "ATTRIB")))
     (redraw cEnt 3)
     (if (setq ss (ssget '((0 . "TEXT,MTEXT"))))
       (foreach x  (vl-remove-if 'listp
                     (mapcar 'cadr (ssnamex ss)))
         (entmod (subst (assoc 1 (entget cEnt))
                        (assoc 1 (entget x))
                        (entget x))))))
   (princ "\n<!> Incorrect Selection <!>"))
 (command "_regenall")
 (princ))
You can not mix a text mtext with an INSERT which is the holder for attributes so you could use ("TEXT","MTEXT","INSERT") then go through the selection looking for certain criteria like is it a block and has name xxxx then get its attributes.
Edited by BIGAL
It would be better if you post a dwg with before and after.
Expand
Below is a video of what I mean. It can convert some other texts, but I have no idea why it doesn't work for the one in white text.
Code I used:
(defun c:newmt (/ cEnt ss textColor)
  (vl-load-com)
      (setq textColor (cdr (assoc 62 (entget cEnt))))
      (redraw cEnt 3)
                         (entmod (subst (cons 62 textColor) (assoc 62 (entget x)) (entget x)))))))
  (princ))
