i have a windows application where i do some calulations for footings, now i want to open the autoCad window on button click event from the form.
the opened AutoCad shouls contain a table showing output of my calculations... so that the user can draw the drawing easily.
it will be nice if i get the code for the same.
Please Help me :huh:
  • 1 month later...
Can you attach an example of the information and the table that you would like to use? I would also assume that AutoCAD is installed on the same machine as your program is.
