Lee, I bet it has to do with your MText object having a background 'mask'. That, among other things, wasn't available in older versions.
See Alan's (CAB) response in this thread.
Man, I had completely forgotten about the subroutine I was working on. I need to get back on that thing. LoL
  • Replies 93
  • Lee Mac
    47
  • The Buzzard
    23
  • NBC
    6
  • alanjt
    4
Posted Images
Ahh! That is a good possibility...
Easiest fix: program is for use on ACAD Versions in which MText Mask is available :D
Happy to help. :)
A quick update - Now allows for quick editing with any text or attributes :)
Oh, and you can click on a viewport to lock it :P
Lee
 ; **=-=-=-=-=-=-=-=-=-=-=- DINFO.lsp =-=-=-=-=-=-=-=-=-=-=-**
 ; **                   by Lee McDonnell                    **
 ; **                 Copyright © May 2009                  **
 ; **         Contact at: CADTutor.net, TheSwamp.org        **
 ; **                DYNAMIC INFORMATION TOOL               **
 ; **  FUNCTION DESCRIPTION:                                **
 ; **  Information about an object is displayed upon the    **
 ; **  user moving the cursor over the object.              **
 ; **  FUNCTION SYNTAX:  DINFO                              **
 ; **  Click or Hit Enter to Exit Program                   **
 ; **  Press "+" to Increase Cursor Pick Box                **
 ; **  Press "-" to Decrease Cursor Pick Box                **
 ; **  Click on Text or Attributes to Edit them.            **
 ; **  Click on a Viewport to Lock it.                      **
 ; **  ADDITIONAL FUNCTIONS:                                **
 ; **  CurMod: Creates Custom Cursor Object                 **
 ; **  cInter: Checks for Intersection & Creates Info Str   **
 ; **  cErase: Erase Information Box and Cursor Object      **
 ; **  blkinfotxt: Creates Information Box                  **
 ; **  dxf: Returns DXF code value                          **
 ; **  verchk: Checks AutoCAD Version                       **
 ; **  PLATFORM RESTRICTIONS:                               **
 ; **  For use on AutoCAD 2000 onwards.                     **
 ; **  Only tested in AutoCAD 2004.                         **
 ; **  WITH THANKS TO:                                      **
 ; **  Andrea Andreetti ~ for providing me with             **
 ; **                     the inspiration to create this.   **
 ; **  VERSION:                                             **
 ; **    1.0  First Release                  ~  09.05.2009  **
 ; **    1.1  ProgEdition Added (Commented)  ~  09.05.2009  **
 ; **    2.0  Text and Attribute Edit Added  ~  09.05.2009  **
Lee, In V1.3 how can we change the color of the "entity name" when moving cursor, these old eyes have a hard time of blue on black.
remainder of info no problem.
cheers
S
Good point Steve,
You'll have to dig through it a bit to change it though, it appears in two places:
Look at the subfunction '_Display', lines 306 and 321, where you see:
{\\C5;
The '5' indicates the colour Blue, so you can change this number to any autocad index colour.
Good point Steve,
{\\C5;
I had looked for "5" and found it, but when it was prefixed by "C" I dared not fool with the "5" at that point. I should back it up, and explore, if it boms, nuts, just go get the failsafe backup and hack / explore more. Explore and learn... that's me.
thanks buddy
S
No worries Steve :)
You can always re-download it if things go tits up :)
  • 3 months later...
Lee, similar to NBC's error back in april (post #66).
Upon hovering over a block with attributes, the block name is substituted for and autocad anonymous block name rather than the actual name. Is there a switch to get the name back, rather than something like *U22 etc
I am using version 1.3 of this program.
Thanks
Pete
Lee, it's an anonymous block with attributes, not a dynamic block.
eg.
block name = Divider - Beef
belongs to = *U161
Just wondering if there is a way to substitute the *U??? for the actual name. If some of the code can be manipulated. I haven't read through all the code with a comb yet, plus i'm still not that au fait either.
Thanks.
Pete
Lee, after a little more testing with a few more blocks, the majority of them do state the block name, though it turns out the particular block i need the name stated on, comes with the anonymous name. Bummer.
**Edit**
Fixed it, did a quick google on converting dynamic block into static ones, turned out that they were dynamic.
Anyway, over on http://www.cadforum.cz/cadforum_en/download.asp?fileID=693 there is a utility, DB2SB, which converts an AutoCAD dynamic block to a static block via VLX Lisp.
So, the end result after a few test blocks, enabled me to convert the dynamic block into a static, then run the Dinfo program and it all works, as it should.
The only thing i have changed on the program is the resultant text, i changed it to ArialNarrow, hope you don't mind... :-)
Thanks
Pete
Edited by tallika_fan
Pete, if its an anonymous block then the name is purely *U### - this is the standard AutoCAD naming format for anonymous blocks :)
Lee, i did write a post yesterday though it disappeared into the void that is the internet.
Basically i did a little more rooting and Googling, and came across this which converts an AutoCAD dynamic block to a static block via a VLX Lisp.
After running this first on the *U### block, then running your Dinfo program it gives me the information that i need.
Cheers
Pete
ps. hope you don't mind, i changed the code for the display font to be arialnarrow, it makes it much clearer on the screen for me.
  • 3 months later...
