OK, thanks to the guys over at ThSwamp.org, I have added code to make it able to use OSnaps during the GrRead loop.
 ; **=-=-=-=-=-=-=-=-=-=-=- DINFO.lsp =-=-=-=-=-=-=-=-=-=-=-**
 ; **                   by Lee McDonnell                    **
 ; **                 Copyright © May 2009                  **
 ; **         Contact at: CADTutor.net, TheSwamp.org        **
 ; **                DYNAMIC INFORMATION TOOL               **
 ; **  FUNCTION DESCRIPTION:                                **
 ; **  Information about an object is displayed upon the    **
 ; **  user moving the cursor over the object.              **
 ; **  FUNCTION SYNTAX:  DINFO                              **
 ; **  Click or Hit Enter to Exit Program                   **
 ; **  Press "+" to Increase Cursor Pick Box                **
 ; **  Press "-" to Decrease Cursor Pick Box                **
 ; **  Press "TAB" to Switch Modes                          **
 ; **  Available Modes:-                                    **
 ; **  DINFO MODE:   General Object Editor                  **
 ; **  LAYISO MODE:  Click on an Object to Isolate Layer    **
 ; **                Shift Click to Turn on all Layers.     **
 ; **  OBJISO MODE:  Click on an Object to Isolate Object   **
 ; **                Type, Shift Click to Turn on all       **
 ; **                Objects.                               **
 ; **  Click on Text or Attributes to Edit them.            **
 ; **  Shift+Click on Attributes to Edit using Text Editor. **
 ; **  Click on a Viewport to Lock it.                      **
 ; **  Click on Drawing Objects to Edit them.               **
 ; **  Click on XLine to Rotate, Shift+Click to Move        **
 ; **  Click on Dimension to Perform Text Override          **
 ; **  ADDITIONAL FUNCTIONS:                                **
 ; **  CurMod: Creates Custom Cursor Object                 **
 ; **  cInter: Checks for Intersection & Creates Info Str   **
 ; **  cErase: Erase Information Box and Cursor Object      **
 ; **  blkinfotxt: Creates Information Box                  **
 ; **  OsLst: Creates a List of Active OSnaps               **
 ; **  OsMark: Creates a temporary OSnap Marker             **
 ; **  arcmake: Creates an Arc Object (Commented)           **
 ; **  dxf: Returns DXF code value                          **
 ; **  vlax-list->3D-point: Converts a SArray lst -> 3D pt  **
 ; **  verchk: Checks AutoCAD Version                       **
 ; **  round: Rounds a Number to Nearest Whole Number       **
 ; **  rtd: Radian to Degree Convertor                      **
 ; **  PLATFORM RESTRICTIONS:                               **
 ; **  For use on AutoCAD 2000 onwards.                     **
 ; **  Only tested in AutoCAD 2004.                         **
 ; **  Requires EXPRESS TOOLS to run.                       **
 ; **  WITH THANKS TO:                                      **
 ; **  Andrea Andreetti ~ for providing me with             **
 ; **                     the inspiration to create this.   **
 ; **  Elpanov Evgeniy  ~ for help with Arc Modification    **
 ; **                     and GrVecs Transformation Matrix  **
 ; **  VERSION:                                             **
 ; **    1.0  First Release                  ~  09.05.2009  **
 ; **    1.1  ProgEdition Added (Commented)  ~  09.05.2009  **
 ; **    2.0  Text and Attribute Edit Added  ~  09.05.2009  **
 ; **    3.0  Line Editor Added              ~  09.05.2009  **
 ; **    4.0  Circle and LWPolyline Editor   ~  10.05.2009  **
 ; **    5.0  Xref and Block Update          ~  10.05.2009  **
 ; **    5.1  Bug fix Editing Nested Ents    ~  11.05.2009  **
 ; **    6.0  Shift-Click Edit Attributes    ~  11.05.2009  **
 ; **    7.0  Xline and Ellipse Edit Added   ~  12.05.2009  **
 ; **    7.1  Dimension Editing Added        ~  12.05.2009  **
 ; **    7.2  Object Colour and Block Name   ~  12.05.2009  **
 ; **    7.3  Spline Edit Added              ~  13.05.2009  **
 ; **    8.0  LayIso and ObjIso Added        ~  14.05.2009  **
 ; **    9.0  Object Snap Added              ~  27.05.2009  **
 ; **    9.1  Orthomode Added                ~  27.05.2009  **
  • 10 months later...
  • Replies 93
  • Lee Mac
    47
  • The Buzzard
    23
  • NBC
    6
  • alanjt
    4
Posted Images
Spent a bit of time on the code for this program, updating it so that the program runs smoother (hopefully!).
Removed Editing functionality and Object Isolation functionality, as I deemed these unnecessary.
New code can be found here.
Lee
I have updated the code for this program to Version 1.2, with an extra GIF for you all to enjoy :D
You can now see what blocks certain objects belong to, and I have added extra fields to the information.
It can all be found here :)
Lee
I gotta hand it to you Lee, quite impressive. Nice work.
Thanks Larry, I'm having fun messing around with it :)
Lee, just a little bit of feedback for you:
I get the following error message whenever I hover over a dynamic block. Note, this only happens when the dynamic block has been changed to something other than the default block state (i.e. stretch/move actions have been done, or the visibility state has changed) and thus the block is 'renamed' to an anonymous block entitled something like *U22.
Am using verstion 1.2 of this program.
Error message:
** Error: bad argument type: lselsetp nil **
I only have one Dynamic block to test with (not being a draftsman, and not knowing how to make Dynamic Blocks...), and I can't seem to reproduce the error. Would you be able to provide a drawing in which the error is occurring? :)
Dig through ToolPalettes, there's several in there.
Thanks Alan :)
Grand, thanks again Lee
You're very welcome NBC, I'm glad you like the program :)
  • 1 month later...
Hi Lee,
Your routine returne follow error for me:
** Error: bad argument type: lentityp nil **
When did you get this error? What were you doing?
When I enter DINFO show this message:
Thanks advance.
I am afraid that I can in 2002, but in 2005 it works perfectly :D
