Lee Mac Posted May 8, 2009 Posted May 8, 2009 I wonder which variant to OP will go with If I were him, I'd go with the talking one - and install it on every PC in his workplace :P Quote
Freerefill Posted May 8, 2009 Posted May 8, 2009 >.> <.> Why not choose all? :3 (defun c:tm( / choice) (setq choice (getrandint 0 23)) (cond ((= choice 1) (c:tm1)) ((= choice 2) (c:tm2)) ((= choice 3) (c:tm3)) ((= choice 4) (c:tm4)) ((= choice 5) (c:tm5)) ((= choice 6) (c:tm6)) ((= choice 7) (c:tm7)) ((= choice (c:tm8)) ((= choice 9) (c:tm9)) ((= choice 10) (c:tm10)) ((= choice 11) (c:tm11)) ((= choice 12) (c:tm12)) ((= choice 13) (c:tm13)) ((= choice 14) (c:tm14)) ((= choice 15) (c:tm15)) ((= choice 16) (c:tm16)) ((= choice 17) (c:tm17)) ((= choice 18) (c:tm18)) ((= choice 19) (c:tm19)) ((= choice 20) (c:tm20)) ((= choice 21) (c:tm21)) ((= choice 22) (c:tm22)) ((= choice 23) (c:tm23)) ((= choice 24) (c:tm24)) ) ) (defun rand( / modulus multiplier increment random) (if (not seed) (setq seed (getvar "DATE")) ) (setq modulus 65536 multiplier 25173 increment 13849 seed (rem (+ (* multiplier seed) increment) modulus) random (/ seed modulus) ) ) (defun getrandint(in ax / ) (fix (* (rand) (- (1+ ax) in))) ) (defun c:tm1( / ) (setvar 'tilemode (if (zerop (getvar 'tilemode)) 1 0 ) ) (princ) ) (defun c:tm2( / ) (setvar 'tilemode (- 1 (getvar 'tilemode)) ) (princ) ) (defun c:tm3( / ) (setvar 'tilemode (boole 6 1 (getvar 'tilemode))) (princ) ) (defun c:tm4( / ) (if (eq (getvar 'tilemode) 1) (setvar 'tilemode 0) (setvar 'tilemode 1) ) (princ) ) (defun c:tm5( / ) (or (and (zerop (getvar 'tilemode)) (setvar 'tilemode 1)) (setvar 'tilemode 0)) (princ)) (defun c:tm6( / spc doc) (vl-load-com) (setq spc (vlax-get (setq doc (vlax-get (vlax-get-acad-object) 'activedocument)) 'activespace ) ) (vlax-put doc 'activespace (- 1 spc)) (princ) ) (defun c:tm7( / ) (cond ((zerop (getvar 'tilemode)) (setvar 'tilemode 1)) (T (setvar 'tilemode 0))) (princ)) (defun c:tm8( / ) (if (member (getvar "ctab") (layoutlist)) (setvar "ctab" "Model") (setvar "ctab" (nth 0 (layoutlist))) ) ) (defun c:tm9( / ) (if (member (getvar "ctab") (layoutlist)) (setvar "ctab" "Model") (command "layout" "set" (nth 0 (layoutlist))) ) ) (defun c:tm10( / ) (setvar 'tilemode (nth (getvar 'tilemode) '(1 0))) (princ) ) (defun c:tm11( / tabnum) (vl-load-com) (setq tabnum(vlax-get-property (vlax-invoke-method (vlax-get-property (vlax-get-property (vlax-get-acad-object) 'ActiveDocument) 'Layouts) 'Item 1) 'Name)) (setvar "ctab" tabnum) ) (defun c:tm12( / ) (vl-load-com) (setvar 'TILEMODE (rem (- 1 (getvar 'TILEMODE)) (rem (car (vl-string->list "TILEMODE")) 86))) (princ)) (defun c:tm13( / ) (setvar 'tilemode (lsh 1 (- (getvar 'tilemode)))) (princ) ) (defun c:tm14( / ) (setvar 'tilemode (fix (cos (getvar 'tilemode)))) (princ) ) (defun c:tm15( / ) (if (= (getvar 'ctab) "Model") (setvar 'ctab (car (layoutlist))) (setvar 'ctab "Model") ) ) (defun c:tm16( / ) (if (vl-position (getvar 'ctab) (layoutlist)) (setvar 'tilemode 1) (setvar 'tilemode 0) ) ) (defun c:tm17( / ) (setvar 'tilemode (- 2 (expt 2 (getvar 'tilemode)))) (princ) ) (defun c:tm18( / ) (eval (list 'setvar "tilemode" (abs (1- (getvar 'tilemode))))) (princ) ) (defun c:tm19( / ) (eval (list 'setvar "tilemode" (1- (getvar 'tilemode)))) (princ) ) (defun c:tm20( / ) (vla-SendCommand (vla-get-ActiveDocument (vlax-get-acad-object) ) ;_ vla-get-ActiveDocument (strcat "(setvar 'tilemode " (itoa (1- (getvar 'tilemode))) ") " ) ;_ strcat ) ;_ vla-SendCommand (princ) ) ;_ defun (defun c:tm21( / ) (setvar 'tilemode (distance '(1 0 0) (list (getvar 'tilemode) 0 0))) (princ) ) (defun c:tm22( / ) (vl-load-com) (vlax-invoke (vlax-create-object "Sapi.SpVoice") "Speak" (vl-list->string (append '(84 105 108 101 109 111 100 101 32 115 101 116 32 116 111 32) (list (ascii (itoa (setvar 'tilemode (- 1 (getvar 'tilemode)))))))) 0) (princ)) (defun c:tm23( / ) (setvar 'tilemode (1+ (- (getvar 'tilemode)))) (princ) ) (defun c:tm24( / ) (apply 'setvar (list 'tilemode (- 1 (getvar 'tilemode)))) ) ... *runs away* Quote
wakibd Posted May 13, 2009 Author Posted May 13, 2009 Thanks everyone for their nice programming skill. But I like to want something different programming. I want to move the tab from Model tab to layout tab if the position of the tab is in model tab but if the tab is in the position in layout tab it does not need to move from layout tab to model tab. The tab have to stay in the layout position. the programmings are posted are moving from model tab to layout tab and layout tab to model tab. if u can it will be great thanks of all programmer again Quote
alanjt Posted May 13, 2009 Posted May 13, 2009 Thanks everyone for their nice programming skill.But I like to want something different programming. I want to move the tab from Model tab to layout tab if the position of the tab is in model tab but if the tab is in the position in layout tab it does not need to move from layout tab to model tab. The tab have to stay in the layout position. the programmings are posted are moving from model tab to layout tab and layout tab to model tab. if u can it will be great thanks of all programmer again so just don't execute the command if in paper. Quote
Lee Mac Posted May 13, 2009 Posted May 13, 2009 so just don't execute the command if in paper. If you really want to be oblivious to what you are doing: (defun c:tm () (or (member (getvar "ctab") (layoutlist)) (setvar "ctab" (car (layoutlist)))) (princ)) Quote
Lee Mac Posted May 19, 2009 Posted May 19, 2009 You could just have this of course: (defun c:tm () (setvar "tilemode" 0)) Quote
