IS THERE ANY COMMAND TO SWITCH MODEL TAB TO LAYOUT TAB.
I USED .BUT IT DOES NOT WORK.
  • Replies 50
  • Lee Mac
    13
  • ronjonp
    10
  • alanjt
    9
  • wizman
    6
(defun c:tm (/)
 (setvar 'tilemode
         (if (zerop (getvar 'tilemode))
           1
           0
Thanks for your lisp program. But when i am using it gives the following error
; error: AutoCAD variable setting rejected: TILEMODE nil
Command:
Strange...what version of cad are you using?
It should have worked, did you copy & paste the code?
here's a slightly differnet version:
(defun c:tm (/)
 (setvar 'tilemode
         (- 1 (getvar 'tilemode))
This's a new one
'tilemode
It was always
"tilemode"
Did it change? -David
I thought they were two of the same?
'tilemode and "tilemode"
Here is my favorite version (I believe Se7en is the original author)
(defun c:tm (/)
 (setvar 'tilemode (boole 6 1 (getvar 'tilemode)))
much less elegant, but since many options are being offered, i thought i'd throw another option in the mix:
(defun c:TM (/)
(if (eq (getvar 'tilemode) 1)
  (setvar 'tilemode 0)
  (setvar 'tilemode 1)
se7en's is by far the most impressive. they all do the same thing. 6 in one, half a dozen in the other.
While we're all at it...
(defun c:tm ()
 (or (and (zerop (getvar 'tilemode))
          (setvar 'tilemode 1))
     (setvar 'tilemode 0))
 (princ))
And to further complicate things:D:
(defun c:tm (/ spc doc)
 (vl-load-com)
 (setq spc (vlax-get (setq doc (vlax-get (vlax-get-acad-object) 'activedocument))
                     'activespace
 (vlax-put doc 'activespace (- 1 spc))
Not sure if COND has been used yet...
(defun c:tm ()
 (cond ((zerop (getvar 'tilemode))
       (T (setvar 'tilemode 0)))
 (princ))
A "CTAB" is fine too..
(defun c:tm( / )
 (if (member (getvar "ctab") (layoutlist))
   (setvar "ctab" "Model")
   (setvar "ctab" (nth 0 (layoutlist)))
 (vl-load-com)
                     'activespace
showoff ;)
Fine i made one...
(defun c:tmz( / )
   (command "layout" "set" (nth 0 (layoutlist)))
here's another one....'-):
(defun c:tm (/)
 (setvar 'tilemode (nth (getvar 'tilemode) '(1 0)))
(defun c:tm (/)
Ingenius - hadn't thought of that one :)
lol it's not pretty but i threw it together
(defun c:tmz ( / tabnum)
 (vl-load-com)
 (setq tabnum(vlax-get-property (vlax-invoke-method (vlax-get-property (vlax-get-property (vlax-get-acad-object) 'ActiveDocument) 'Layouts) 'Item 1) 'Name))
 (setvar "ctab" tabnum)
Couldn resist:
[b][color=RED]([/color][/b][b][color=BLUE]defun[/color][/b] c:tm  [b][color=RED]([/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]vl-load-com[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]setvar[/color][/b] [b][color=DARKRED]'[/color][/b]TILEMODE
         [b][color=RED]([/color][/b][b][color=BLUE]rem[/color][/b]
           [b][color=RED]([/color][/b][b][color=BLUE]-[/color][/b] [b][color=#009900]1[/color][/b]
             [b][color=RED]([/color][/b][b][color=BLUE]getvar[/color][/b] [b][color=DARKRED]'[/color][/b]TILEMODE[b][color=RED])[/color][/b][b][color=RED])[/color][/b]
                 [b][color=RED]([/color][/b][b][color=BLUE]car[/color][/b]
                   [b][color=RED]([/color][/b][b][color=BLUE]vl-string->list[/color][/b] [b][color=#ff00ff]"TILEMODE"[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b] [b][color=#009900]86[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
 [b][color=RED]([/color][/b][b][color=BLUE]princ[/color][/b][b][color=RED])[/color][/b][b][color=RED])[/color][/b]
