the command is from a .cui on a server. i have a toolbar icon which i use to initiate it.
Regardless of the command i use afterwards, my OSnaps remain 512.
i just found that using this macro '_setvar "osmode" 4263 , works and i've tied it to Shift + RightClick. The ' somehow lets it run transparently (not sure of the term - i'm a month old noob with ACAD :D ) and i can now return my Osnap settings whilst using the messed-up command. 8)
  • Replies 21
  • Seath
    5
  • rshort9900
    5
  • lpseifert
    3
  • yawdapaah
    2
set your osnaps
type setvars
take note what the number is
example
you want a button setting osnap to insert
take note of the setvar then write that number under a button using the commands
C^Csetvar;osmode;512;^C^C
