Dana W Posted August 25, 2020 Share Posted August 25, 2020 So you waste your one and only first impression by opening a nearly one year old thread just to bitch and moan about how crappy AutoCad is? 1 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted August 26, 2020 Share Posted August 26, 2020 I like the Zoom undo myself, quick for zooming back to the previous zooms or several. If you want to go way back after several zooms, just go to the toolbar and the UNDO drop down area and select the point at which you want to go to, easy peasy. Also, as mentioned in my previous post, type UNDO to the command line and choose the down arrow for options. Maybe, if people read the Help File (or press F1). 1 Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 26, 2020 Share Posted August 26, 2020 These types of complaints coming from new users are usually due to frustration because they can't understand why it doesn't work the way they think it should work. They immediately blame the program instead of asking for help because it makes them feel inadequate and they don't like that. So they blame the software instead of owning up to their lack of knowledge of the program. Then after they realize it was just a matter of knowing how things are supposed to be done, they insult the messenger. Wait for it... Quote Link to comment Share on other sites More sharing options...
Wernek Posted January 6, 2022 Share Posted January 6, 2022 It has been over 16 years since Autodesk decided to ignore this user request. Best thing I did: abandon autocad and switch to "BIM" (Archicad). It's extremely faster, easier, intuitive and well accepted in the eyes of my customers. 1 1 Quote Link to comment Share on other sites More sharing options...
Dana W Posted January 14, 2022 Share Posted January 14, 2022 Well, thank you. I was wondering how condescending a single poster can be. Now I know. 1 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted January 14, 2022 Share Posted January 14, 2022 Like stated, I prefer the way it is and as mentioned, just use the drop down next to the UNDO/REDO buttons at the top to go back to where you want to be. Easy Peasy, Lemon Squeezy. SMFH! 1 Quote Link to comment Share on other sites More sharing options...
jcclow Posted August 2, 2022 Share Posted August 2, 2022 (edited) I'm in 2018 and 2022 the full version... Type "UNDO" in the command line (without the quotes for all entries) Type "C" for Control Type "C" for Combine Type "Y' for Yes Voilá! All zooms, except for one started from the menu, will be combined into one undo/redo step until you issue another command https://help.autodesk.com/view/ACDLT/2023/ENU/?guid=GUID-2729A466-B199-4840-B92B-4D8A38A8ADB8 Edited August 2, 2022 by jcclow Quote Link to comment Share on other sites More sharing options...
