Rhino on a 64bit system
I was wondering if someone could tell me if Rhino will run on a windows xp 64 bit system????
Rhino v4.0 will run as a 32bit application on x64 bit Windows, but it won't take any advantage of the added computing.
We have Rhino 3.0 and we are not looking to gain anything we are just making sure that it will run ok. We are having our company tech guys build us a new comp for modeling and we run multiple softwares and we are trying to make sure this will run with no problems.
http://www.simplyrhino.co.uk/rhinotraining/hardware.html
Quote comes from the above link:
  Quote
Windows XP Professional X64 Rhino 4.0 is a 32 bit application and will run on XP Pro X64 (but only in 32 bit mode) and although this is not officially supported we have found this to be stable in a professional environment. Running Rhino 4 in a 64 bit environment will allow it to access more memory (a total of 3GB) and the 64 bit version of Rhino 5 currently in development will allow significantly greater amounts of RAM to be accessed.
