Hi, there may be a really simple explanation to this, but whenever i import a block, edit a block, closedown CAD and sometimes when i do nothing; every arc ive drawn straightens out into a straight line. Im only working in 2D, and have to select the arcs and type "flatten" - "no" everytime to get them to revert back to an arc.
Arcs appear as straight lines
Common causes:
1. VIEWRES is set too low (WHIPARC has to be off)
2. SHADEMODE has been set to other than 2D
3. WHIPARC is set to 0. (Viewres will have no effect when whiparc is set to 1)
Viewres was set to 100, so I set it higher and it seems to have done the trick. Thanks for the help.
Do you do a REGEN when they straighten out? Works for me all the time... Pain, but it works..
Never tried regen, but after setting the viewres to 1000, its not done it again, and hasnt slowed the program down. I was just typeing flatten, no, which worked, but it always reverted back.
The range on viewres is 1 - 20,000. I generally keep mine between 2,000 and 5,000.
