Showing results for tags 'z coordinates'.
    • z coordinates ×
  1. Hi Everyone, i,m looking for LISP Program that will display Z value of 3D points as A.L=0.000 (Asphalt Level) and prompt for height between Asphalt level and top of curbstone levels because its varies and display as C.L=0.000 (Top of Curbstone level) on screen. i have a lot of data to proc...
  2. Hello, Could you help me with the following question? I would like to filter all the texts and multileaders at Z=0. I could solve it for texts by using the following code, but it does not work for multileaders when I simply change TEXT to MULTILEADER. How could I do it? (sslength (ssget...
  3. Greetings. I have a simple routine that allows to write the Z coordinates in a profile. It works, but if I'm working in an area with a small zoom, it has a behavior that distorts the triangle or does not ensure the removal of the text relative to the upper base of the triangle. If the zoom is furt...
