Showing results for tags 'xrefs problem'.
Not sure if this is how to pose AutoCAD questions. If not, please tell me the appropriate method. I'm using several drawing files received from architect firms. These files are showing xrefs loaded into each other: A.dwg is guest file of B.dwg; while B.dwg is guest file of A.dwg. Why would th...
Hi I am relatively new to AutoCAD. I'm running into problems when I try to bring in an architects plan into my civil base plan. Only some of the lines and objects appear in my working drawing. A lot of the live layers in the architects plans do not xref into my drawing and I cannot figure out wh...
- 5 replies
- xref object
- xref
I know that in ACAD you can use the xref manager to see where the actual file for the xref resides on your computer/server/etc. What I'm curious about is whether or not the inverse action is possible. Can you somehow access the file (not the output sheet where it's being xref-ed) and see what other...
- 9 replies
- xref
- inverse xref
Is there a lisp routine to control the draw order of x-refs. I want the x-refs to "sent to the back". Every time the drawing regenerates the draw order changes. Any help in this area would be appreciated.
