Showing results for tags 'xref reload'.
Need a lisp routine that only loads a modified xref. Have tried searching on various forums, however, none of them seem to do reload a modified xref. I have one that loads all xrefs but some of the xrefs are turned off for a particular purpose and/or not required in drawing. Any assist would be greatly appreciated.
Updated XREF causes viewport layer visibility to reset
BakedPotato posted a topic in AutoCAD Drawing Management & Output
Hello all, I have a Civil 3D drawing with an xref to another drawing. When I change the xref and update the reference in the main drawing, all the xref layers I had frozen in the main drawing viewport suddenly come on. Xref layers that are frozen in model space or turned off stay frozen or turned off after updating, but if an xref layer was only frozen in the viewport, it comes on after updating the xref. Any ideas? -
Hi, What are the possibilities concerning copying or ripping objects from an xref without having to open the xref or refedit, copy to 0,0 and paste to 0,0? Also, about reloading a xref. I usually enter xref and from the dialog box, I do a reload. Is there an alternative way of doing a reloading? Thanks.
