Showing results for tags 'xref problem'.
    • xref problem ×
Found 6 results
  1. os windows 10 updated to Windows 10 pro. externalreferences command is not working in autocad 2014 LT. please advice
  2. lando67
    xref problem
    Hi all, I'm new here and have a question about an xref problem in autocad 2015. I'm trying to xref a drawing to use as a sheet border, and the xref is showing up in paperspace with large bullseye tags at the bottom left and top right corners. Does anyone know what this is and how to get rid of...
  3. I'm running Chris Wade's Lisp: Xref to Attach/Overlay: http://autocadtips.wordpress.com/2012/04/03/autolisp-globally-change-xref-attachment-type/ but it's giving me this: "; error: Automation Error. Duplicate key" I'm running Autocad 2011 here, with 37 Xref's We always have to change...
  4. I copied and pasted some xrefs into another drawing. They all show up but I am unable to select any xref except for one. I can't turn any layer off either when trying to select it or opening the layers window. They are not on locked layers and are showing up in the xref window. I’m completely lost a...
  5. Hello all, I've just joined this forum and looking forward to it's friendly community! I have a problem for now, can't solve one thing - it's just somehow Xref drawing doesn't appear in layout/sheet space. Sorry for my English. If it's clear, does anyone knows how to make it? I'd appreciat...
  6. Hello, I had to update some drawings from AutoCAD 2007 and each of these drawings has at least 7 XRef files attached to it. Each of these files have about the same number of XRef files attached to them as well. These drawings keep going this way for about 3 more layers. I copied all of the C...
