Showing results for tags 'x-ref'.
I want to delete Xref-dependent layer. AutoCAd says I can't delete them. I want to delete them. How can I do that?
Edit Reference in Place - Colour change issue
DRAFTOLOGIST posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Has anyone experience this or know why this happens? dwg A is x-refed to dwg B. am working on dwg B & click on x-ref and go into Edit reference in place. if I now click on > any object and go into properties & change the color from bylayer to red (for example) and save changes. -every...- 10 replies
- layer color
- layer
Hello, I had to update some drawings from AutoCAD 2007 and each of these drawings has at least 7 XRef files attached to it. Each of these files have about the same number of XRef files attached to them as well. These drawings keep going this way for about 3 more layers. I copied all of the C...
- 2 replies
- xref missing
- xref
Plotting with Layer States, STBs and Multiple X-Refs
CuriousCAD posted a topic in AutoCAD Drawing Management & Output
Hello, I am working on a massive project with many x-refs. We are using an STB, along with layer states for line weights. We are plotting from a sheet file, where our, and consultants' drawings, are x-reffed in. If we apply the layer state in the SHEET file, we will need to know all layers... -
Scale problem x-reffing between two files
benjaminzkrauss posted a topic in AutoCAD 2D Drafting, Object Properties & Interface
Hi...having some trouble with a group of files I received from someone working for me and was wondering if someone can help me. I have a file that is x-reffed into another file. In both instances the drawing has the same measurements, but when I make a viewport in the receiving file the drawing (in... -
Not seeing all layers from X-ref in viewports
jordison posted a topic in AutoCAD Drawing Management & Output
Hi all, Im having some problems with a file im working on. I have a file with an x-ref, when im in the model space i can see all layers i want to see, but in the viewports i created in the file i noticed that 2 layers(layers that i really need to see) dont show up. Ive checked the freeze/thaw, o... -
Every so often when others in the office and now, today, myself have been editing an x-ref in place it will not allow us to save the changes we have made. First when you try the dialogue box flashes up , as attachment. I press F2 to bring up the command line box and have copied the relevent lin...
