Showing results for tags 'windows 7'.
Using Windows Search for Information Inside Drawings
07lodgeT posted a topic in AutoCAD Drawing Management & Output
Hello, Is there a way of searching across a number of AutoCAD files for files containing particular text? This used to be possible in Windows XP, but does now not work in Windows 7 annoyingly. We have thousands of DWG files that have been drawn up over the past 20 years and to be able to search... -
DesignScript for AutoCAD - Anyone Using It?
3D generator posted a topic in AutoCAD 3D Modelling & Rendering
Hi All, This is something I've waited for since December 2010 when I first learned about it: http://designplaygrounds.com/deviants/about-generative-design-platforms-by-mark-loomis/ http://labs.autodesk.com/utilities/designscript This plug-in to AutoCAD does the same thing that Grasshoppe...- 5 replies
- generative design
- designscript
- (and 3 more)
Disable .DWG Thumbnail Previews in Windows 7
lamensterms posted a topic in Tutorials & Tips'n'Tricks
Hey guys, Just switched from XP (old faithful) to a new Win7 machine... I've used a little Win7 in the past and it's safe to say I am not it's greatest fan. One of the features which had bugged me was the way in which Win7 manages it's file thumbnail previews. If you want thumbnails for ima...- 3 replies
- thumbnails
- disable
Hi, I just switched over to a 64-bit computer. I'm using AutoCAD 2004 and windows 7. I never had problems with FATAL ERROR crashes with my old 32-bit computer. However now when I open the same files that I used to open on my last computer I'm getting a lot of FATAL ERROR messages that I never...
- 1 reply
- fatal error
- 64-bit
AutoCAD 2012, Windows 7 64bit and Sheet Sets
rwsice9 posted a topic in AutoCAD Bugs, Error Messages & Quirks
We have 2 machines running Windows 7 64bit, and AutoCAD 2012. We use sheet sets extensively. When inserting a "sheet list table", which we use as our drawing index, it takes anywhere from 5-20 minutes on our Win7 machines, but takes only 2-3 seconds on our WinXP machines. Has anyone else run in...- 4 replies
- sheet sets
- autocad 2012
How can I run Revit 2012 32-bits version in Windows 7 64-bit?
FL1992 posted a topic in Autodesk Revit
Last week I downloaded Revit Architecture 2012 from the Autodesk webpage into my computer. The file I downloaded is a 32/64 bit .rar. I started to run the installer and an error (Error 1722) appeared. After some research and investigation in the web I founded out that I can't run the 64bit versi... -
I recently upgraded to windows 7 and AutoCAD 2012, when I hit save as the cursor or highlighted field is in the directory area not the file name. When I'm detailing I use save as a lot and this little quirk causes me about three extra steps, and kills my rhythm. Our XP machines defaulted to the fi...
I had the free student version of autocad 2012, and it worked fine for a couple of months. Then a couple of days ago, I suddenly could not open the program. I did not try to open a specific file, just the autocad program itself. It showed me this error message: fatal error unhandled e0434352h E...
- 7 replies
- installation
- fatal error
AutoCAD 2010, Windows 7, and Compatibility Mode... OH MY
TCorris posted a topic in AutoCAD Bugs, Error Messages & Quirks
Recently upgraded my work computer to run Windows 7. First, I couldn't run The new Windows 7 Aero without AutoCAD being slow, jumpy, and unresponsive. Realized my graphics card sucked and I had to disable Aero. Viola, Worked great. Then I worked with drawings referencing PDF underlays... No Bu...- 17 replies
- compatibility mode
- autocad 2010
I work in an architecture office and we are FINALLY starting to upgrade our computers. We have already purchased one computer. It is windows 7 64-bit. We use AutoCAD 2002 and the boss man wants to keep using AutoCAD 2002 because he has everything set up just the way he wants it. He is just too l...
- 15 replies
CLEAN INSTALL OF WINDOWS 7 (replacing 64 VISTA) Civil 3D 2011 Database Backup?
Old Timer posted a topic in AutoCAD General
I am getting ready to perform a CLEAN install of Windows 7 (to replace VISTA) Are all the Civil3D 2011 "Database" (Surfaces, Alignments, Style Settings,etc...) sotred within each .dwg file, or is there a master database faile ? I am NOT using AutoCAD Vault Any tips on the reinstall to be a...
