Showing results for tags 'window mullion'.
    • window mullion ×
  1. I want to make a simple dynamic block showing a plan section of a window with one mullion between the window jambs. I've succeded making the block stretchable to any given length that is required. The problem is, that I can't figure out how to keep the mullion right in the middle between the j...
