Showing results for tags 'width factor'.
    • width factor ×
  1. I've been trying to find existing lisp routines to do the following for a while now (off and on). While I have found some that will change values of Attributes or the text width for every piece of text in a drawing, that is not what I need done. I need a lisp routine that will be manually modifi...
  2. Hello all, got a little text style problem over here Background info: I am trying to tackle the problem of making a searchable PDF from a drawing with simplex font. From what I have read that is not possible without using OCR, which is unreliable. To work around this I am trying to conver...
