Showing results for tags 'where is it?'.
    • where is it? ×
  1. Greeting gents, I was scouting on Autocad 2009 and was looking through a way that you use constraints like you use in the 2000 LT version, But i can't find the setting as i am too new to this version. I wanted to use constraints so that two lines are parallel and right angles of the shape. The h...
