Showing results for tags 'vlax-curve'.
Error for ObjectID of polyline using vlax-curve-*
HelplessIntern posted a topic in AutoLISP, Visual LISP & DCL
I have just started learning AutoLISP from different posts on the forums and through the reference material from Autodesk but, I am hitting an error in my lisp routine that I don't know how to fix. I am trying to right a while loop that will go through a nested list and use information in the select...- 10 replies
- objectidcollection
- autolisp code problems
vba equivalent for vlax-curve-getClosestPointTo ? - to measure perpendicular distance
DS-precast posted a topic in .NET, ObjectARX & VBA
Hello All I'm trying to write a vba routine which allows me to get the starting width and length of a polyline shape by specifying three points. The polyline will usually be made up of orthographic straight lines (but not always) Points 1 and 2 are the start and end points of the first side,...- 6 replies
- vba
- perpendicular distance
