Showing results for tags 'vla-sendcommand'.
Hello! I'm performing a count in order to create a report from a dwg file. Counting functioncan be called at any time, but necessarily runs on close - when I also count the edit time. For that I'm using a reactor. That works fine. Prior to start the counting I'd like to ov...
- 6 replies
- vla-sendcommand
- overkill
How can I identify a drawing that it is not the active one? vla-get-ActiveDocument? And if so... What is the purpose for vla-sendcommand? I want to run a lisp routine in a drawing that it is not the active one What is proper syntax for both situations? I have been able to make activ...
- 7 replies
- vla-get-active-document
- vla-activate
