Showing results for tags 'visual basic'.
    • visual basic ×
Found 5 results
  1. Hi Everyone, I am trying to get this script to work but I keep getting error messages that say sendkeys.vbs is an unknown variable this is the script select item.cid case 61, 4 sendkeys.vbs "maskview {ENTER}" Endselect I've heard that a lisp could do this but my boss doesn't w...
  2. Hi all, I'm currently using AutoCAD 2014. I'm use to using AutoCAD but have never used VBA or AutoLISP before. Really just found out about them from doing some research on the internet and hoping for some help with my dilemma. I have a floor plan already drawn and each individual room alre...
  3. I have a Visual Basic compiled ActiveX dll, (call marVbUtils.dll, with a lot of map utilites) written in Visual Basic 6.0. It works fine in XP with Map 2009 There, I connect with the ActiveX dll from visual lisp, like this: (vla-GetInterfaceObject (vlax-get-acad-object) ""marVBasic.marVbUtils") a...
  4. Hi everybody, should anyone help me converting this vb code to vlisp? Public Declare Function LoadKeyboardLayout Lib "user32" Alias "LoadKeyboardLayoutA" (ByVal pwszKLID As String, ByVal Flags As Long) As Long LoadKeyboardLayout "00000409", 1 End Function any help is greatly apprecia...
  5. Hi All, is it a way to use vba code directly from within Visual LISP? Assume that we use this visual lisp code: (vla-addcustominfo (vla-get-summaryinfo (vla-get-activedocument (Vlax-get-acad-object)) ) "Key" "Value" ) Is it possible to use: ActiveDocument.SummaryInfo.AddCustomInf...
