Showing results for tags 'visibility states'.
    • visibility states ×
Found 10 results
  1. Hello all, I have posted as a reply on other post to try and find a way to make what seems to be impossible...possible...First and foremost...I KNOW THE EXACT EQUIVALENT OF SQUAT!! about writing, reading, or understanding LISP or the verbiage associated with it. That being said, I would like to...
  2. Hello guys! I have a block with 6 visibility which I can change easyli with the drop-down list. It works well. But if I change the scale of the block it lose the drop-down list. In the block editor I can see the 6 different states but no drop-down list in the model space. Why? Could you...
  3. hello i have an existing dynamic block with several visibilities states. i would like to add another one but when i did it, it changes one of the existing visibility state my question is : how to add a visibility state to an existing block without changing existing states. thanks Phil
  4. To anyone out there, I'm working on a project and I need to get a block count of a select number of blocks within model space broken down to the various visibility states . I've used some of the Lee-Mac.com .lsp's, which work awesome but what i'm looking for is a combination of the three .lsp fi...
  5. I'm trying to cut down on the number of visibility states for a block under development. Currently I have a rectangle, 4'x2', with other lines that I don't need to modify. What I want to do is to stretch the rect into a 4'x4' square and add 2 circles in the corner. I have no problem with the stretch...
  6. Hello, I found this to interesting and proven on having more than 1 Visibility Parameter. The below link redirects to a page of 2 guys work Andrey Lazebny and Nikolay Poleshchuk. http://www.private.peterlink.ru/poleshchuk/cad/2009/tainypod12e.htm Their block works perfectly, unfortunatelly I...
  7. I have a drawing with several dynamic blocks (over 1000 block references) with visibility states. I recently noticed that all of the blocks no longer have the option to change the visibility state (i.e. the upside down blue triangle no longer appears when clicking on the block). If I insert a n...
  8. I need some help with this dynamic block. The visibility states are not working properly and always show the attributes. I'll be grateful for your help. P&ID Valve Symbol.dwg
  9. Hey everyone! First time poster, long time user. I run Autocad 2010LT at work, where I do fire alarm drawings. I've been trying to create a dynamic block (sort of a one stop-shop) for my wiring diagrams, and wanted to include device text with it. My question is, is there a way I can create...
  10. The Question: Can Visibility States be changed by an Attribute Value instead of the drop down arrow? The Situation: I am building an annotative block that the user wants to change appearance (ie different hatches inside a circle) based on an attribute value (1,2 or 3). The attribute is invisibl...
